CUSTOM_BLOCK 1, CUSTOM_BLOCK 2
Current Version: 2.0.2
Released: 2013-10-27
noth
phpBB.com User: noth
Post by noth »
did you know that you can do MORE than 1 custom block?
I just tried it :D and Custom_Block 2 CAN be completely different to Custom_Block 1, this is VERY USEFUL!! :mrgreen:
so you can create a whole series of Custom_Blocks I think, I have done 2 and they contain totally different contents!! 8-) this is great!
well I did not set any groups for the first Custom Block so it displays all the time of course. For my 2nd custom block I set it for Guests, but it displays all the time, so maybe the Custom Blocks take their permissions from the first one I don't know - oh well, it's still good to be able to have more than 1 ;)
Re: CUSTOM_BLOCK 1, CUSTOM_BLOCK 2
noth wrote: For my 2nd custom block I set it for Guests, but it displays all the time, so maybe the Custom Blocks take their permissions from the first one I don't know - oh well, it's still good to be able to have more than 1 ;)
You may only select guests, if guests are allowed to see only the block.
noth
Post by noth »
can each block have it's own permissions?
I appreciate that permissions exist to start with under ACP > Groups permissions > Reg Users > Advanced Pertmissions > Misc
but say that you have allowed Guests AND Reg Members under this, then all your blocks have to match that? or can some BLOCKS say "Guests Only" ?
noth wrote:can each block have it's own permissions?
Yes!
noth wrote:or can some BLOCKS say "Guests Only" ?
Yes!
You can see many custom blocks with authorization for certain groups only.
Forgive them only group rights, but no special user rights.
Then they can keep track.
Make it into a profile of each group and test them.
