Move Board3 copyright?
Current Version: 2.0.2
Released: 2013-10-27
Elysea
phpBB.com User: Elysea
Post by Elysea »
Hello
I would like to move the copyright on the portal to the same place as the phpbb copyright, so they are standing together and the board3 copyright gets on every page as well.
Is that allowed?
If so, where do I find it?
Re: Move Board3 copyright?
Elysea wrote:Hello
Is that allowed?
We do not want them the copyright to one other point.
If they do, it may be they will receive no support is offered here more.
I think the Google translator translation kind of mixed some things up there.
It is ok if you copy the Coypright notice to your footer.
You can find the code in styles/prosilver/template/portal/portal_body.html and styles/subsilver2/template/portal/portal_body.html.
The prosilver code:
<div class="copyright">Powered by <a href="http://www.board3.de/">Board3 Portal</a> &copy; 2009 - 2011 Board3 Group</div>
The subsilver2 code:
		<div class="copyright" align="center">Powered by <a href="http://www.board3.de/">Board3 Portal</a> &copy; 2009 - 2011 Board3 Group</div>
Elysea
Post by Elysea »
Thank you.
Yes, I don't want to remove it, just put it the same place as the phpbb copyright witch also can be seen on the portal (so it's also fair board3's can been seen on the forum)
