Your Portal Version: 2.0.0
Boardlink: http://www.manazery.net
1.0.6 portal withour problem
I tried to google it but didnt find solution
Hi all
I have issue with updating from 1.0.6 to 2.0.0. Everything looks fine and runs without problem but when I try to reach Board3 settings in ACP it says
Cannot find module ./../includes/acp/acp_reimg.php
I did everything what was in .xml file for updating from 1.0.6 and really dont know where is a problem. Can you help me with that? Thanks for answer
Update from 1.0.6 to 2.0.0
Re: Update from 1.0.6 to 2.0.0
It may be they have a problem with the module ==> ReIMG Image ResizerMartan wrote: Cannot find module ./../includes/acp/acp_reimg.php
http://www.phpbb.com/customise/db/mod/r ... em-t_95314
I do not think the portal is to blame.
It was my bad, I was updating with DB and DB wanted reimg and I forgot that... sorry and thanks for answer
