[Release] breizh shout box 1.5.0 for board3 portal v2.0.0
Theriddler
Post by Theriddler »
i've made a block for board 3 portal 2.0.0
create a new file called 'portal_breizhshout.php' and placed it in /portal/modules/
* @package Board3 Portal v2 - breizhshout Block
* @Author theriddler (phpbbservice.nl)
* @ignore
if (!defined('IN_PHPBB'))
	exit;
* @package Modulname
class portal_breizhshout_module
	* top		1
	* left		2
	* center	4
	* right		8
	* bottom	16
	public $columns = 21;
	* Default modulename
	public $name = 'PORTAL_BREIZHSHOUTBOX';
	* Default module-image:
	public $image_src = '';
	* module-language file
	public $language = 'portal_breizhshout_module';
	* custom acp template
	public $custom_acp_tpl = '';
	public $hide_name = true;
		global $config, $template, $phpbb_root_path, $phpEx, $auth, $user, $cache, $db;
		// Start Breizh Shoutbox
if (isset($config['shout_version']))
        if ($config['shout_enable'])
            shout_display();
// End Breizh Shoutbox --
		return 'breizh_center.html';
		return array(
			'title'	=> 'PORTAL_BREIZHSHOUTBOX',
			'vars'	=> array(),
	* API functions
		return true;
		global $db;
		return true;
create a new language file called 'portal_breizhshout_module.php'
and place it in: /language/en/mods/portal/
* DO NOT CHANGE
	exit;
	$lang = array();
// DEVELOPERS PLEASE NOTE
	'PORTAL_BREIZHSHOUTBOX'		=> 'Breizh shoutbox',
create a new html template file for the portal blok called 'breizh_center.html' and place that into /style/prosilver/template/portal/modules/
<!-- IF S_DISPLAY_SHOUTBOX and POS_SHOUT_PORTAL_TOP and PORTAL_SHOUT -->
                        <!-- INCLUDE shout_body.html -->
<br style="clear:both" />
refresh templates and install the block.
Finish
best regards.
Efferd75
Re: [Release] breizh shout box 1.5.0 for board3 portal v2.0.
Post by Efferd75 »
Hello, can the shoutbox will appear in the right block of the portal?
And you can build that too at subsilver2?
niwes
phpBB.de User: niwes
phpBB.com User: niwes
Post by niwes »
dont work in my forum :cry:
Thist is Original Image
______________________________________
and when i youre Code´s inst. Image
My HP http://www.raccoongaming.de
Eventuell überprüfst Du mal die Einstellungen im Adminbereich unter den Shoutbox-Einstellungen.
Da in der Anleitung steht:
Choosing Display the shoutbox in multiple pages and positions in pages adjustable in ACP.
Presence of a second private shoutbox with separate rights and ability to show the main shoutbox in a popup and in a lateral retractable panel .........
Die Wahl anzeigen shoutbox auf mehreren Seiten und Positionen auf den Seiten verstellbar ACP.
Anwesenheit eines zweiten privaten shoutbox mit separatem Rechte und Fähigkeit, die wichtigsten shoutbox in einem Popup und in einer seitlichen versenkbare Fenster anzuzeigen .........
niwes
Post by niwes »
archivar wrote:Eventuell überprüfst Du mal die Einstellungen im Adminbereich unter den Shoutbox-Einstellungen.
dort kann man nur das hier einstellen
Display on the portal:
Decide if you want to display the shoutbox on the forum portal.
(Make sure you have entered the code lines in portal.php and portal_body.html)
 Ja /  Nein
Shoutbox Position on the portal:
Decide what position you want to assign to the shoutbox on the forum porta
Oben / Unten
EDIT:
es währe noch zu erwähnen....
Installierte Portal Ver. 2.0.1 und nicht wie oben angegeben 2.0.0 :oops:
 Ja /  Nein
Oben / Unten
Was mich bei dem Code irritiert ist diese Zeile :oops: :
Bei allen Zusatz-Portal-Modulen ab v.2.xx muss dort nicht´s eingefügt werden und es muss auch keine Datei verändert werden, außer den Änderungen die das Basis-Modul verlangt!
Alle Zusatz-Portal-Module sollten normalerweise nur aus 3 Dateien bestehen: /knowledge/kb_show.php?id=57
Dein Modul besteht normalerweise aus 3 Dateien (als Beispiel verwenden wir die Modul Klasse portal_beispiel):
language/en/mods/portal/portal_beispiel_module.php
portal/modules/portal_beispiel.php
styles/prosilver/template/portal/modules/portal_beispiel_side.html oder portal_beispiel_center.html
Da ich diese Shoutbox nicht verwende kann ich das auch nicht überprüfen.
niwes
Post by niwes »
archivar wrote: Bei allen Zusatz-Portal-Modulen ab v.2.xx muss dort nicht´s eingefügt werden und es muss auch keine Datei verändert werden, außer den Änderungen die das Basis-Modul verlangt
da weis ich auch leider nicht mehr weiter :oops:
das komische ist das der gesammte portal bereich von diesem code befallen wird so wie wenn er nicht geschlossen wird
niwes wrote: da weis ich auch leider nicht mehr weiter :oops:
Muss es denn unbedingt diese Shoutbox sein?
niwes
Post by niwes »
archivar wrote:Muss es denn unbedingt diese Shoutbox sein?
Jap hatte auch schon eine eigene und den mChat aber die finde ich am besten! mir fehlt ja im grunde nur der richtige portal code
das blöde ist es gibt etliche seiten im netz die portal 2 haben und die shoutbox aber alle behalten es schön für sich :roll:
Ok-ich bau mir das Ding mal selber ein. :roll:
niwes
Post by niwes »
archivar wrote:Ok-ich bau mir das Ding mal selber ein. :roll:
coole sache danke 8-)
Die Installation des Basismoduls (nur nach Anleitung) und des Zusatz-Portal-Modules verliefen bei mir, ohne Tricks und ohne doppelten Boden, ohne Probleme!!!
Ich musste noch nicht einmal an den Einstellungen herum schrauben.
Wo bei Dir der Fehler liegt kann ich nicht erkennen.
Überprüfe nochmal gewissenhaft den Einbau des Mods.
Roger123
phpBB.de User: Roger123
phpBB.com User: Roger123
Post by Roger123 »
Hatte es selber probiert und finde diese version einer Shoutbox top. Könnte man nicht ein Modul/Block dafür erstellen?
Was noch da fehlt ist eine deutsche sprachdatei bin aber dabei das zu übersetzen
mfg
Roger123
Frage: Ist es möglich alle Downloads für Module/Blocks in einem neuen DL-Bereich zusammenfassen? ?. Wäre einfacher bei der Suche ;)
http://rh-welt.net/
niwes
Post by niwes »
oh man na gut :(
danke werde mich mal der Sache annehmen :geek:
Roger123 wrote:Hatte es selber probiert und finde diese version einer Shoutbox top. Könnte man nicht ein Modul/Block dafür erstellen?
mfg
Roger123
Ist doch schon vorhanden, wenn Du den ersten Beitrag vom Themenstarter lesen würdest ;) ====> viewtopic.php?f=54&t=5566#p31048
