Portal » Board index
Current Version: 2.0.2
Released: 2013-10-27
georgesnijs
Post by georgesnijs »
On the Index page i cannot switch between Board index and Portal, the Portal 'buttom' is not present on the index page.
Where i can change this or find this to change:
<li class="icon-home"><a href="./portal.php">Portal</a> » <a href="./index.php" accesskey="h">Board index</a> <strong>‹</strong> <a href="./viewforum.php?f=7">Portal</a> <strong>‹</strong> <a href="./viewforum.php?f=49">Board3 Portal 2.0.x - English Support</a></li>
Thank you very much.
Georges.
Re: Portal » Board index
What style do they use?
georgesnijs
http://www.thekingdomofgod.be/
this is my website if you go to the index page you see no Portal buttom.
georgesnijs wrote:http://www.thekingdomofgod.be/
They have removed the copyright of phpBB. Half of them receive no support.
Add to the copyright of phpBB on again.
I can not understand why removing the copyright, because they can use link for support.
georgesnijs
ok i am sorry forgive me it is fixed now.
is this link ok or not?
georgesnijs wrote:ok i am sorry forgive me it is fixed now.
Do you see the download package in install.xml and change it to overall_header.html and overall_footer.html.
georgesnijs
i am very happy with the portal, great job done, as you can see, a lot of features work perfectly. thanks for support. i cannot find the file you has given me i looked in the template editor and in the root folder.
georgesnijs wrote:i am very happy with the portal, great job done, as you can see, a lot of features work perfectly. thanks for support. i cannot find the file you has given me i looked in the template editor and in the root folder.
See it here: http://www.thekingdomofgod.be/styles/pr ... eader.html
http://www.thekingdomofgod.be/styles/pr ... ooter.html
georgesnijs
ok i have found overall_header.html, what i have to change now what line? thanks
georgesnijs wrote:ok i have found overall_header.html, what i have to change now what line? thanks
You should use the style / template cache empty, so the changes become visible.
georgesnijs
must i change
by this one ?
Eddy
Post by Eddy »
I think you don't understand how to use the install.xml - file.
Knowledge Base: Where can I find installation instructions?
Datenvermeidung ist besser als Datenschutz und günstiger als die Datenhaltung und -Pflege.
georgesnijs wrote:must i change
by this one ?
For file contents should the button "CODE" in the "Editor" use.
Try to modify the files with the editor "Notepad + +"
I wonder how they did it, try installing that portal when they can not change the overall_header.html and overall_footer.html is changing as in the install.xml. You should make backup board. Then they experiment until it works.
Board3.de - Rules | We ask for your attention==>
Topic-Bumping is only accepted at least 24 hrs. after posting.
So I removed the other 3 posts.
If they feel wronged they should contact the board administrator.
Open that file in your browser and please use the
 BBCode.
georgesnijs
<li class="icon-home"><a href="./portal.php">Portal</a> » <a href="./index.php" accesskey="h">Board index</a> <strong>‹</strong> <a href="./viewforum.php?f=7">Portal</a></li>
I changed to this line in header and footer, and everything works now perfectly. Thank you very much for your support. Very appreciated.
You can see it here: http://www.thekingdomofgod.be/
