Upgrade process
Current Version: 2.0.2
Released: 2013-10-27
shadzy89
Upgrade process
Post by shadzy89 »
Hi guys, Just want to say fantastic job with this portal!!
I am currently on 2.0.0b and I would like to upgrade to 2.0.0 as it suggests me to do.
I may have not used the search facility here correctly however I can find the upgrade process to upgrade the system stuff only and leave my custom blocks as they are.
I used AutoMOD to install this so I thought it would be matter of uploading the files and installing again but I am hesitant about removing anything.
Any confirmation of where I can do this safely??
If this is a question somehow asked already I am sorry maybe my searching this morning sucks to the nth degree
Re: Upgrade process
Secure it to her board!
Please do not use auto-mod!
Look in the download package contrib/update_200b1_to_200/update.xml.
If you upgrade only, then the content should remain the blocks.
shadzy89
Re: Upgrade process
Post by shadzy89 »
Ok so am iright in thinking, i just replace the files that came inside root folder, and edit session.php ?
Re: Upgrade process
shadzy89 wrote:Ok so am iright in thinking, i just replace the files that came inside root folder, and edit session.php ?
Yes, and here you are running domain / install / index.php
