Addon: Download Block for B3P v2.0.0
Addon Version: 2.0.2
Addon Author: phpbb-projekte.de, Oxpus and WileCoyote
Addon Description:
This portal block will show you the latest downloads in your board3 Portal v2.0.0 and newer.
Addon Requirements: Board3 Portal v2.0.0 and Hotschi's Download MOD 6.5.3 by oxpus
Addon Download: here
Instructions:
Upload the module package via the ACP or just upload the content of the ZIP-File into the root of your forum.
Anweisungen:
Lade das Modul Paket über den Admin-Bereich hoch oder lade den Inhalt der ZIP-Datei in das Hauptverzeichnis deines Forums.
[ABD] Download Block for B3P v2.0.0
WileCoyote
- phpBB.de User: WileCoyote
- phpBB.com User: WileCoyote
lg,
WileCoyote
________________________________________
Get some German MOD Translations at
wu-systems.at - An Austrian phpBB Community
WileCoyote
Xx_iDon_xX
- phpBB.com User: Xx_iDon_xX
Re: [Release] Download Block for B3P v2.0.0
i get this error when i go to my portal,how can i fix this so that the download module could show and work properly?
[phpBB Debug] PHP Warning: in file [ROOT]/portal/modules/portal_download_side.php on line 64: include(./dl_mod/classes/class_dlmod.php) [function.include]: failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file [ROOT]/portal/modules/portal_download_side.php on line 64: include() [function.include]: Failed opening './dl_mod/classes/class_dlmod.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php')
Fatal error: Class 'dl_mod' not found in /home/playboy/public_html/portal/modules/portal_download_side.php on line 65
WileCoyote
It seems that the file class_dlmod.php is not present in the directory /dl_mod/classes/.
lg,
WileCoyote
WileCoyote
Xx_iDon_xX
ok ive fixed the errors by downloading the dl_mod now everything is fine excpept when i activate the portal download mod it doesnt appear on the portal
WileCoyote
It will only appear if there are some downloads available which can be shown.
lg,
WileCoyote
WileCoyote
