I recently tried to install the portal but it does not show. I can only see the portal when I add /portal.php to the url and it contains no blocks at all.
How can I make the portal show correctly?
no portal after install
Re: no portal after install
Did you run the installer?
RigPa
Yes I did and no errors.
I guess the main url should redirect to the portal so something went wrong anyway.
ixl
- Sponsor
- phpBB.de User: IXL
- phpBB.com User: IXLUKCOM
It doesnt redirect the url. Not unless you change the hosting permissions so it becomes the default.
There is also a "portal" permission you need to enable into your forum groups.... check that as well.
RigPa
Thanks - that works!
ixl
- Sponsor
Happy to help...RigPa wrote:Thanks - that works!
