Your Portal Version: 2.0.0b1
Your phpBB Type: phpBB 3.0.10
Your knowledge: Soso
Boardlink: http://www.aimclan.net
PHP Version: 5.2.17
MySQL Version: 5.0.95-community
Googled for answers but found none
I have tried using the Custom Block normally, also by editing it's template and the data value in mysql. The board seemed to ignore the SQL value, and shows blank outputs if I just included the PHP code.
I have a php script that outputs some match information and I wish to include it on the main page of the site for select member groups only. I have used iFrames but the dynamic nature of the output makes it look very ugly. I wish to use a simple php "include" function and embed the data. Is this doable?
Custom Block php code?
Re: Custom Block php code?
You can't add PHP code in a custom block. You would have to create one yourself:
knowledge/kb_show.php?id=54
plague69
Thanks for your reply! Great job on Board3!
ixl
- Sponsor
- phpBB.de User: IXL
- phpBB.com User: IXLUKCOM
Could you not add the code into a php file, then create an iframe set of code with a link to that php file into a custom block.
Its what I use for 2 blocks on ours.
