If the board language is set to a language other than English, it's not enough to upload just the language files from the root folder:
/root/language/en/*.*
Other language files are contained in the directory "/languages/your language" which is located ABOVE the root portal directory in the package (zip) file!
This is because the MODX-Packaging-Guidelines dictate that additional language files have to be in the directory "/languages" rather than in the /root/ directory of the package.
Independent from that your language files have to be uploaded in the "/language/your language" directory of your forums!
[EN] Solution: "Language file xyz.php couldn't be opened!"
