If your in the forum and click the logo in the header it links to the forum not the portal.
Same when in portal, the header logo links to the forum.
How do I change this to link back to the portal.
Header Logo Links to Forum not Portal
AussieD
Re: Header Logo Links to Forum not Portal
Looking for a little will not hurt.AussieD wrote:If your in the forum and click the logo in the header it links to the forum not the portal.
See it here ==> site_logo link to Portal
kdxrider
Might want to test that with the latest version. When I used that fix on my test forum it breaks the style template. Layout gets all screwy and becomes one column sort of attached to the phpbb header. Make sure you try it on a test forum first!
Then she did something wrong!kdxrider wrote:Might want to test that with the latest version. When I used that fix on my test forum it breaks the style template. Layout gets all screwy and becomes one column sort of attached to the phpbb header.
You can be sure we have tested!kdxrider wrote:Make sure you try it on a test forum first!
You can test it on this page.
A link to their forum would be helpful.
AussieD
The instructions worked for me, thanks.
I had to change the overall-header in proformell style rather than the prosilver.
