Error on Update from 2.0.0b1 to 2.0.0
Current Version: 2.0.2
Released: 2013-10-27
cwjs
phpBB.de User: cwjs
phpBB.com User: cwjs
Post by cwjs »
On the install - action I get the message below, I searched for the file but it does not exist
Board3 Portal - Fail
Database type :: mysql4
Warning
One or more errors occured during the requested action. Please make a full record of any errors and ask the mod author for assistance.
Refreshing the prosilver template
ERROR: Could not open the file ../styles/prosilverdrafts.html for reading.
Thanks
Clive
cwjs
phpBB.de User: cwjs
Re: Error on Update from 2.0.0b1 to 2.0.0
Post by cwjs »
Now if I refresh the theme (prosilver) I get
General Error
Could not open ./../styles/prosilver/template/portal/modules/announcements.html
This is one of the files I had to delete in the update
Any help please
Clive
Please try this here:
Browse to install/index.php and run the installer
Refresh your Styles:
cwjs
phpBB.de User: cwjs
Post by cwjs »
Hi Archivar
this will uninstall the update , is that what you want me to do ?
Clive
cwjs wrote:Hi Archivar
Clive
No!
Sorry :oops: - do first-time only:
cwjs
phpBB.de User: cwjs
Post by cwjs »
Hi Archivar,
Ok I will not run it again, I cannot find any sign of the file prosilverdrafts.html the message talks about ?
Clive
cwjs wrote:Hi Archivar,
Clive
The error should be:
/prosilver/template/drafts.html
It lacks the drafts.html in prosilver
cwjs
phpBB.de User: cwjs
Post by cwjs »
Hi Archivar,
I have a /prosilver/template/drafts.html is the install/index.php incorrect ?
I assume that because when I refresh the template and it is still looking for the /prosilver/template/portal/modules/announcements.html ( that the instructionssaid delete) that the install has not fully worked.
Any thoughts on how I can sort this out please
Clive
Copy (overwrite) all Portal-files in the forum directory and all styles.
cwjs
phpBB.de User: cwjs
Post by cwjs »
OK I have done that but when I refreshed the theme (prosilver) I got
General Error
again (This is one of the files I had to delete in the update)
I copied it from my backup and it now refreshes OK but not sure if I should have done that.
Clive
cwjs wrote:OK I have done that but when I refreshed the theme (prosilver) I got
General Error
The reason is that an ancient portal file tries to find the old file.
Check it on your server that all of the old portal-files overwritten.
If they "FTP" use it to check the file permissions.
Directories should have a value of 755.
Files should have a value of 644.
cwjs wrote:I copied it from my backup and it now refreshes OK but not sure if I should have done that.
Clive
You should not do that.
cwjs
phpBB.de User: cwjs
Post by cwjs »
I have just uploaded again, filezilla did not report any failures so I assume that all the new files were updated, I renamed the styles/prosilver/template/portal/modules/announcements.html and got the same error.
Interestingly the Portal admin is reporting
Board3 Portal is up to date
Current Version
2.0.0
Latest Version
2.0.0b1
cwjs wrote: Interestingly the Portal admin is reporting
Current Version
2.0.0
Latest Version
2.0.0b1
That's at with me that way and will soon be changed.
But this has nothing to do with their mistakes.
Make sure you don't have any old portal files in your template folder, i.e. portal_center.html.
