MOD-version: 2.0.0
MOD-description:
Adds a portal with several blocks to your forum. You can change the settings, move the blocks, add new blocks and more in the ACP. A converter for Board3 Portal 1.0.6 is included in the package.
Changes to version 2.0.0b1
- Replaced German language vars with English ones
- Fixed 2 small errors in calendar language file
- Fixed incorrect links to convert instruction
- Added note to author notes that PHP5 is required
- Fixed incorrect handling of utf8 characters in custom blocks
- Fixed missing height and width in module images of custom blocks
- Modified module title to "Attachments" as suggested by wang555
- Fixed incorrect timezone handling of events
- Removed number in latest bots title
- Centered clock in prosilver
- Added br-tag in forumlist.html to prevent issues in custom styles
- Fixed small cosmetic errors in prosilver
- Added correct padding between headerbar and portal body
- Hide module image settings in center, top & bottom column
- Added missing permission check for calendar events
- Fixed incorrect position of event desc in future events (prosilver)
- Modified style of calendar in subsilver2
- Fixed: Jumpbox doesn't care if it is enabled in the ACP
- Added a few rtl fixes
- Fixed: Unread topics do not get displayed
- Add possibility to define a different class for callback functions
- Moved trim_message tool to includes folder
- Added missing lang entries for removed events
- Fixed incorrect ordering of users in leaders module
- Added htmlspecialchars_decode for message before trimming
- Allow duplicate inclusion of module if it's in a different column type
- Fixed incorrect arrow directions when using rtl language (ACP)
- Disabled poll module for the side columns
- Merged small whois online block into whois online module
- Fixed missing module_status in board3_basic_install()
- Add missing update instructions for 2.0.0b1
- Fix size of input boxes
- Add missing class references
- Fixed "unknown column" issue when installing
- Fixing incorrect size of module box for oneliners
- Get rid of magic numbers in portal.php
- Make sure we don't try to copy folders
- [Fix] Don't let Bots use styleswitcher
- Added missing language vars and removed useless ones
- Purge caches via install file
- Fixed exceeding of max execution time when using trim message tool
- Moved duplicate javascript to acp_portal.js
- Hide modules that can't be added
MOD-download: php-version: php 5.+
phpBB-version: phpBB 3.0.10
phpBB-styles: prosilver, subsilver2
phpBB-languages: English, German - More languages here: viewforum.php?f=55
MOD-demo: soon
Portal ACP Demo: soon
Preview install instructions: soon
