I have a partially built weather mod for the US that uses a custom profile field for zip code for the location. It's a badly edited version of the current mod in development here, combined with the old weather mod from B3P version 1. I can't upload the files here, but if somebody wants to help me figure out how to fix it, I can upload the code to my next post.
So far, I have a mod that actually works. However, I can't get add the module without getting an error, I can't get into the ACP settings, and I can't delete it without removing it from the database manually. It DOES get added and it DOES work.
Just need a little help finishing it up. Anybody interested?
Weather mod for US using Accuweather
Re: Weather mod for US using Accuweather
Okay, well... Without further ado, let me just post what I have and I'll see if anybody can see the mistakes - and there are many! First, you create a custom profile field for zip code (field ID = zip_code). I limited it to five characters, as I think that's what Accuweather uses in the US and it has to match.
Next, the language file (english only at the moment): root/language/en/mods/portal/portal_weather_module.php
This is modified from the other module version, which I don't understand and since we don't use country codes, etc., I stripped some of it out.
Then, the portal_weather module, in root/portal/modules, which is taken from the new european module with the old weather.php code inserted:
I think this needs to be added to the end before the last "}":
* API functions
return true;
global $db;
$sql = 'DELETE FROM ' . CONFIG_TABLE . '
WHERE ' . $db->sql_in_set('config_name', $del_config);
return $db->sql_query($sql);
Am I right?
In styles/template/prosilver/weather_center.html, I have:
I haven't made a side block yet, but Accuweather offers a small version, so it should be simple.
Anyway, with a (small) database repair, I did manage to install this block, though I still get errors when I try to edit the block, and I'm hoping somebody can help me finish this thing up. If I go to try to modify the settings in the ACP, I get this error:
Thanks!
* @package Board3 Portal v2 - AccuWeather Weather Module
* DO NOT CHANGE
if (!defined('IN_PHPBB'))
exit;
$lang = array();
// DEVELOPERS PLEASE NOTE
'PORTAL_WEATHER' => 'Regional Weather',
// ACP
'ACP_PORTAL_WEATHER_SETTINGS' => 'Weather settings',
* @ignore
exit;
* @package Weather
class portal_weather_module
* top 1
* left 2
* center 4
* right 8
* bottom 16
public $columns = 31;
* Default modulename
public $name = 'PORTAL_WEATHER';
* Default module-image:
public $image_src = 'portal_weather.png';
* module-language file
public $language = 'portal_weather_module';
* custom acp template
public $custom_acp_tpl = '';
public $hide_name = false;
global $config, $template, $user, $db;
$sql = "SELECT pf_zip_code
FROM " . PROFILE_FIELDS_DATA_TABLE . "
WHERE user_id = " . $user->data['user_id'];
$zip_code = $db->sql_fetchfield('pf_zip_code');
$db-> sql_freeresult($result);
$template->assign_vars(array(
'WEATHER_ZIP' => (!empty($zip_code)) ? $zip_code : '80201', // Change 20099 to the wished default ZIP code
return 'weather_center.html';
return 'weather_side.html';
return array(
'title' => 'PORTAL_WEATHER',
* API functions
return true;
global $db;
Am I right?
<div class="post bg2" style="margin-bottom: 0px">
<!-- Weather Start -->
<div style='width: 728px; height: 90px; background-image: url( http://vortex.accuweather.com/adcbin/netweather_v2/backgrounds/hurricane_728x90_bg.jpg ); background-repeat: no-repeat; background-color: #0F243A;' ><div style='height: 74px;' ><script src='http://netweather.accuweather.com/adcbin/netweather_v2/netweatherV2.asp?partner=netweather&tStyle=dark2&logo=1&zipcode={WEATHER_ZIP}&lang=eng&size=11&theme=hurricane&metric=0&target=_self'></script></div><div style='text-align: center; font-family: arial, helvetica, verdana, sans-serif; font-size: 11px; line-height: 16px; color: #FDEA11;' ><img style='float: right; padding-right: 5px;' src='http://vortex.accuweather.com/adc2004/common/images/misc/netweather_v2/adcwhite.png' /></div></div>
<!-- Weather End -->
<span class="portal-corners-bottom-inner"></span></div></div></div>
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
I know I'm asking a LOT, but if somebody can help very briefly (I hope), we'll have a US weather block for B3P v.2.[phpBB Debug] PHP Warning: in file [ROOT]/adm/index.php on line 389: Invalid argument supplied for foreach()
[phpBB Debug] PHP Warning: in file [ROOT]/includes/acp/acp_portal.php on line 205: Invalid argument supplied for foreach()
[phpBB Debug] PHP Warning: in file [ROOT]/includes/acp/acp_portal.php on line 319: Invalid argument supplied for foreach()
Thanks!
