Request _block_config X_Silver
mister_don
phpBB.de User: mister_don
phpBB.com User: mister_don
Post by mister_don »
Hello, could you adapt to style X_Silver 3.0.9.1 for board3 Portal: 2.0.0b1, please thank you.
I put url for one can not attach file.
style comes home :http://www.skin-lab.com/
my _block_config
    <!--version $Id: _block_config.html 544 2010-03-27 12:35:25Z bisounours_n $ //-->
    <!-- DEFINE $LR_BLOCK_H_L = '<div class="c-h-l"><div class="c-h-r"><div class="c-h-c"><div class="c-h-title"></div></div></div></div><div class="v-left"><div class="v-right"><div class="panel"><h6>' -->
    <!-- DEFINE $LR_BLOCK_H_R = '</h6>' -->
    <!-- DEFINE $LR_BLOCK_F_L = '</div></div></div><div class="c-f-l"><div class="c-f-r"><div class="c-f-c">' -->
    <!-- DEFINE $LR_BLOCK_F_R = '</div></div></div><br style="clear:both" />' -->
    <!-- DEFINE $C_BLOCK_H_L = '<div class="c-h-l"><div class="c-h-r"><div class="c-h-c"><div class="c-h-title">' -->
    <!-- DEFINE $C_BLOCK_H_R = '</div></div></div></div>' -->
    <!-- DEFINE $C_BLOCK_F_L = '<div class="c-f-l"><div class="c-f-r"><div class="c-f-c">&nbsp;' -->
    <!-- DEFINE $C_BLOCK_F_R = '</div></div></div>' -->
my site
http://misterdon.altervista.org/forum/portal.php
Re: Request _block_config X_Silver
mister_don wrote:Hello, could you adapt to style X_Silver 3.0.9.1 for board3 Portal: 2.0.0b1, please thank you.
my site
A config I do not write for everyone, because many additional changes to the blocks, and because it is not for all the latest version available for this style.
Config for her with their changes to the blocks they try this:
<!--version $Id: _block_config.html v2.0.0b1 adapted by: archivar $ //-->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div></div>' -->
<!-- DEFINE $C_BLOCK_F_L = '<div class="c-f-l"><div class="c-f-r"><div class="c-f-c">' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="c-h-l"><div class="c-h-r"><div class="c-h-c"><div class="c-h-title">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</div></div></div></div>' -->
mister_don
thanks boy ;)
how can I move icon and title, as screenshout?
Refresh your Styles:
:mrgreen:
The icon should be allowed because of little space away.
You can change this in the config:
mister_don
My site looks like this,
and not as I want
thanks
mister_don
I have already done this
Open: styles/X_Silver/theme/stylesheet.css
Code:Select all
Code:Select all
and not in "mods.css".
They have changed the contents of portal.css and copies of these contents in the mods.css. The blocks are with you are not original. That is to blame!
:roll:
mister_don
/*  phpBB 3.0 Style Sheet
	Style name:			X-Silver
	Based on style:		proSilver (this is the default phpBB 3 style)
	Original author:	subBlue ( http://www.subBlue.com/ )
	Modified by:		Alpha Trion (http://www.skin-lab.com)
	Copyright 2006 phpBB Group ( http://www.phpbb.com/ )
	Skin Modification Copyright 2010 Skin Lab Group (http://www.skin-lab.com)
@import url("common.css");
@import url("links.css");
@import url("content.css");
@import url("buttons.css");
@import url("cp.css");
@import url("forms.css");
@import url("tweaks.css");
@import url("skinextra.css");
Now this is my stylesheet
the result does not change
please if you have a complete portal for x_silver, you can add links to download it?
thanks
Previously, they had the:
@import url("mods.css");
mister_don
true, first, yes, now I did as you suggested, but nothing changes
mister_don
I solved by changing the portal_body.html, and the various blocks in modules
now my site is so
Thanks for helping me ;)
Return to “Config requests”
