Does anyone have a Gallery Block for nick's phpbb Gallery version 1.1.5
The latest version installs fine until I try to install the database, then it quits at the compatibility section
Gallery block for 1.1.5
Re: Gallery block for 1.1.5
That wicked search function might have actually helped you:
http://www.flying-bits.org/viewtopic.php?f=98&t=3378
- phpBB.com User: Crocodile442
Thanks, I did try that but it didn't locate it for me. Besides, this one is for the 2x version of the Portal and was hoping to find one for the 1x version.
Gallery Block is not developed further for B3P v.1.0.6.Crocodile wrote:of the Portal and was hoping to find one for the 1x version.
Yep - unfortunately...
