Style Version: 2.0.7
Style Download: http://www.stsoftware.biz/phpbb30_style.etech.html
to: root/styles/eTech/template/portal/*.*
to: root/styles/eTech/theme/images/portal/*.*
open: root/styles/eTech/template/breadcrumbs.html
<a href="{U_INDEX}">{L_INDEX}</a>open: root/styles/eTech/template/overall_header.htmlCode: Select all
<tr> <td class="navrow">
<tr> <td id="contentrow">
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN and (U_MCP or U_ACP) --> <div class="pm-notify-new"><div class="pm-notify-header">{L_INFORMATION}</div>{L_BOARD_DISABLED}</div> <!-- ENDIF -->
<!-- INCLUDE breadcrumbs.html --> <br />
Tip: Add these lines on a new blank line after the preceding line(s) to find.open: root/styles/eTech/template/portal/_block_config.htmlCode: Select all
<!-- Config for the left and right blocks //--> <!-- DEFINE $LR_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right">' --> <!-- DEFINE $LR_BLOCK_H_R = '</div></div></div>' --> <!-- DEFINE $LR_BLOCK_F_L = '' --> <!-- DEFINE $LR_BLOCK_F_R = '<br style="clear:both" />' --> <!-- Config for the center blocks //--> <!-- DEFINE $C_BLOCK_H_L = '<div class="cap-div"><div class="cap-left"><div class="cap-right">' --> <!-- DEFINE $C_BLOCK_H_R = '</div></div></div>' --> <!-- DEFINE $C_BLOCK_F_L = '' --> <!-- DEFINE $C_BLOCK_F_R = '<br style="clear:both" />' --> <!-- Images-URL //--> <!-- DEFINE $WHOS_IMAGES = '/images/whosonline.gif' --> <!-- DEFINE $NO_AVATAR_IMG = '/images/no_avatar.gif' --> <!-- Vertical distance between left/right and center Blocks --> <!-- DEFINE $BLOCK_DISTANCE = '10px' --> <!-- show Icons in left/right Blocks? 0=no 1=yes --> <!-- DEFINE $S_BLOCK_ICON = 0 --> <!-- override the column width settings of the ACP for this style? 0=no 1=yes --> <!-- DEFINE $S_COLUMNS_WIDTH_OVERRIDE = 0 --> <!-- override the column width settings of the ACP - set the width if enabled --> <!-- DEFINE $PORTAL_LEFT_COLUMN_OVERRIDE = '200' --> <!-- DEFINE $PORTAL_RIGHT_COLUMN_OVERRIDE = '200' --> <!-- override for rtl styles ... only needed if you have an RTL language --> <!-- IF S_CONTENT_DIRECTION eq 'rtl' --> <!-- DEFINE $LR_BLOCK_H_L = '<table class="tablebg" cellspacing="1" width="100%"><tr><th><span style="float: right">' --> <!-- ENDIF -->
nach: root/styles/eTech/template/portal/*.*
nach: root/styles/eTech/theme/images/portal/*.*
Öffne: root/styles/eTech/template/breadcrumbs.html
<a href="{U_INDEX}">{L_INDEX}</a>Öffne: root/styles/eTech/template/overall_header.htmlCode: Select all
Hinweis: Diese Zeile(n) werden in einer neuen Zeile nach den/der gerade gesuchten eingefügt.Öffne: root/styles/eTech/template/portal/_block_config.htmlCode: Select all
