Style Version: 1.0.3
Style Download: http://www.stsoftware.biz/phpbb30_style.ca_gen2.html
to: root/styles/ca_gen2/template/portal/*.*
to: root/styles/ca_gen2/theme/portal.css
to: root/styles/ca_gen2/theme/images/portal/*.*
open: root/styles/ca_gen2/template/overall_footer.html
<a href="{U_INDEX}" accesskey="h">{L_INDEX}</a>open: root/styles/ca_gen2/template/overall_header.htmlCode: Select all
<!-- IF U_PORTAL --><a href="{U_PORTAL}" accesskey="h">{L_PORTAL}</a> » <!-- ENDIF -->
<!-- header start -->
<div id="logo"><a href="{U_INDEX}"><span>{SITENAME}</span>{SITE_LOGO_IMG}</a></div> <!-- header end -->
<a href="{U_INDEX}" accesskey="h">{L_INDEX}</a>FindCode: Select all
Tip: Add these lines on a new blank line before the preceding line(s) to find.open: root/styles/ca_gen2/theme/stylesheet.cssCode: Select all
Tip: Add these lines on a new blank line after the preceding line(s) to find.open: root/styles/ca_gen2/template/portal/_block_config.htmlCode: Select all
<!-- Config for the left and right blocks //--> <!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="block-border block-block"><div class="block-content"><ul class="topiclist"><li class="header"><dl class="icon"><dt style="margin-left: 2px; margin-top: 0px; width: 140px;">' --> <!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul><div style="padding:4px;">' --> <!-- DEFINE $LR_BLOCK_F_L = '</div>' --> <!-- DEFINE $LR_BLOCK_F_R = '<div class="block-footer"></div></div></div></div>' --> <!-- Config for the center blocks //--> <!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="block-border block-block"><div class="block-content"><ul class="topiclist"><li class="header"><dl class="icon"><dt style="margin-left: 2px; margin-top: 8px;">' --> <!-- DEFINE $C_BLOCK_H_R = '</dt></dl></li></ul><div style="padding:4px;">' --> <!-- DEFINE $C_BLOCK_F_L = '</div>' --> <!-- DEFINE $C_BLOCK_F_R = '<div class="block-footer"></div></div></div></div>' --> <!-- Config for compact blocks //--> <!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg"><div class="block-border block-block"><div class="block-content"><ul class="topiclist"><li class="header"><dl class="icon">' --> <!-- DEFINE $CC_BLOCK_H_R = '</dl></li></ul><div style="padding:0px;">' --> <!-- Images-URL //--> <!-- DEFINE $NO_AVATAR_IMG = '/images/no_avatar.gif' --> <!-- Vertical distance between left/right and center Blocks --> <!-- DEFINE $BLOCK_DISTANCE = '10px' --> <!-- show Icons in left/right Blocks? 0=no 1=yes --> <!-- DEFINE $S_BLOCK_ICON = 1 --> <!-- postbody top (default 1 by prosilver) 0=no 1=yes --> <!-- DEFINE $S_POSTBODY_TOP = 1 --> <!-- override the column width settings of the ACP for this style? 0=no 1=yes --> <!-- DEFINE $S_COLUMNS_WIDTH_OVERRIDE = 0 --> <!-- override the column width settings of the ACP - set the width if enabled --> <!-- DEFINE $PORTAL_LEFT_COLUMN_OVERRIDE = '200' --> <!-- DEFINE $PORTAL_RIGHT_COLUMN_OVERRIDE = '200' -->
nach: root/styles/ca_gen2/template/portal/*.*
nach: root/styles/ca_gen2/theme/portal.css
nach: root/styles/ca_gen2/theme/images/portal/*.*
Öffne: root/styles/ca_gen2/template/overall_footer.html
<a href="{U_INDEX}" accesskey="h">{L_INDEX}</a>Öffne: root/styles/ca_gen2/template/overall_header.htmlCode: Select all
<a href="{U_INDEX}" accesskey="h">{L_INDEX}</a>FindenCode: Select all
Hinweis: Diese Zeile(n) werden in einer neuen Zeile vor den/der gerade gesuchten eingefügt.Öffne: root/styles/ca_gen2/theme/stylesheet.cssCode: Select all
Hinweis: Diese Zeile(n) werden in einer neuen Zeile nach den/der gerade gesuchten eingefügt.Öffne: root/styles/ca_gen2/template/portal/_block_config.htmlCode: Select all
