CA Orbital / CA Vintage (Base: prosilver)
Style: CA Orbital / CA Vintage
Style Version: 1.0.6
Style Download: http://www.stsoftware.biz/phpbb30_style.ca_orbital.html
Style Download: http://www.stsoftware.biz/phpbb30_style.ca_vintage.html
This Guide is written for ca_orbital, but it works for ca_vintage also.
If you want to use this Guide for ca_vintage you just have to replace "ca_orbital" with the Name of your Style in this Guide.
to: root/styles/ca_orbital/template/portal/*.*
to: root/styles/ca_orbital/theme/portal.css
to: root/styles/ca_orbital/theme/images/portal/*.*
open: root/styles/ca_orbital/template/overall_footer.html
<a href="{U_INDEX}" accesskey="h">
open: root/styles/ca_orbital/template/overall_header.html
<!-- header start -->
	<div id="logo"><a href="{U_INDEX}">{SITE_LOGO_IMG}<span>{SITENAME}</span></a></div>
	<!-- header end -->
	<div id="page-body">
open: root/styles/ca_orbital/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/ca_orbital/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/ca_orbital/theme/stylesheet.css
open: root/styles/ca_orbital/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="block-caption block-caption-header">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</div><div class="block-border block-block block-with-caption"><div class="block-content"><div class="block-inner"><div class="block-inner2">' -->
<!-- DEFINE $LR_BLOCK_F_R = '<div class="block-clear"></div></div></div></div><div class="block-footer"><span></span><div></div></div></div>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="block-caption block-caption-header">' -->
<!-- DEFINE $C_BLOCK_H_R = '</div><div class="block-border block-block block-with-caption"><div class="block-content"><div class="block-inner"><div class="block-inner2">' -->
<!-- DEFINE $C_BLOCK_F_R = '<div class="block-clear"></div></div></div></div><div class="block-footer"><span></span><div></div></div></div>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="block-caption block-caption-header">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</div><div class="block-border block-block block-with-caption"><div class="block-content"><div class="block-inner"><div class="block-inner2">' -->
additional changes: poll_center.html
Diese Anleitung wurde für ca_orbital geschrieben, funktioniert aber auch für ca_vintage.
Wenn ihr diese Anleitung für ca_vintage nutzen wollt, müsst ihr einfach "ca_orbital" in diese Anleitung mit dem Namen eures Styles ersetzen.
nach: root/styles/ca_orbital/template/portal/*.*
nach: root/styles/ca_orbital/theme/portal.css
nach: root/styles/ca_orbital/theme/images/portal/*.*
Öffne: root/styles/ca_orbital/template/overall_footer.html
Öffne: root/styles/ca_orbital/template/overall_header.html
	<!-- header end -->
Öffne: root/styles/ca_orbital/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/ca_orbital/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/ca_orbital/theme/stylesheet.css
Öffne: root/styles/ca_orbital/template/portal/_block_config.html
zusätzliche Änderungen: poll_center.html
Reason: Fehler in der Anleitung korrigiert
