Adding a new group in Team Block - v.2.0.0b1
Current Version: 2.0.2
Released: 2013-10-27
robra
phpBB.de User: robra
phpBB.com User: robra
Post by robra »
To add a new group, you will need edit the files:
- /styles/your_style/template/portal/modulesleaders_side.html
- root/portal/modules/portal_leaders.php
- root/language/en/mods/portal/portal_leaders_module.php
- root/language/en/common.php
Let's go add a new group called "Colaborators", but first you have to create this group in your Forum, from ACP.
Basically is:
1- /styles/your_style/template/portal/modulesleaders_side.html:
Find the line...
... and Add Before in new line:
	<br style="clear:both" />
	<strong>{L_COLABORATORS}</strong><br />
	<!-- BEGIN col -->
		<span style="float:left;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="float:left; padding-left:5px; padding-top:2px;"><strong>{col.USERNAME_FULL}</strong></span><br style="clear:both" />
	<!-- BEGINELSE -->
		{L_NO_COLABORATORS_P}
	<!-- END col -->
2- root/portal/modules/portal_leaders.php:
Find the line...
'WHERE'        => 'u.group_id = g.group_id AND ' . $db->sql_in_set('g.group_name', array('ADMINISTRATORS', 'GLOBAL_MODERATORS')),
... and Replace with:
'WHERE'        => 'u.group_id = g.group_id AND ' . $db->sql_in_set('g.group_name', array('ADMINISTRATORS', 'GLOBAL_MODERATORS', 'Colaborators')),
Find the lines...
                elseif ($row['group_name'] == 'GLOBAL_MODERATORS')
                    $which_row = 'mod';
... and Add After, in new lines:
                elseif ($row['group_name'] == 'Colaborators')
                    $which_row = 'col';
3- root/language/en/portal_leaders_module.php:
Find the line...
'NO_MODERATORS_P'        => 'No Moderators',
... and Add After, in new line:
'NO_COLABORATORS_P'        => 'No Colaborators',
Find the line...
'PORTAL_LEADERS_EXT_EXP'    => 'The standard block lists all admins/mods, while the extended block includes all non-hidden groups with a legend.',
... and on line, Replace the text "admins/mods" for "admins/mods/colaborators".
4- root/language/en/common.php:
Find the line...
    'G_BOTS'                    => 'Bots',
... and Add after, in new line:
    'G_COLABORATORS'        => 'Colaborators',
Find the line...
    'CLICK_VIEW_PRIVMSG'    => '%sGo to your inbox%s',
    'COLABORATORS'        => 'Colaborators',
[]. Image
Source: http://www.suportephpbb.com.br
robra
Re: Adding a new group in Team Block
Post by robra »
If you want only change the position of the group names on block, you have to change the positions of the lines on file /styles/your_style/template/portal/modulesleaders_side.html. The original file is:
	<strong>{L_ADMINISTRATORS}</strong><br />
	<!-- BEGIN admin -->
		<span style="float:left;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="float:left; padding-left:5px; padding-top:2px;"><strong>{admin.USERNAME_FULL}</strong></span><br style="clear:both" />
	<!-- BEGINELSE -->
		{L_NO_ADMINISTRATORS_P}<br /><br />
	<!-- END admin -->
	<strong>{L_MODERATORS}</strong><br />
	<!-- BEGIN mod -->
		<span style="float:left;"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16" height="16" alt="" /></span><span style="float:left; padding-left:5px; padding-top:2px;"><strong>{mod.USERNAME_FULL}</strong></span><br style="clear:both" />
	<!-- BEGINELSE -->
		{L_NO_MODERATORS_P}
	<!-- END mod -->
If you want the Moderators stay first, then, the lines will be:
	<!-- BEGIN mod -->
	<!-- BEGINELSE -->
		{L_NO_MODERATORS_P}
	<!-- END mod -->
	<!-- BEGINELSE -->
	<!-- END admin -->
[]. Image
Re: The Team Block Modify
Posts separated and moved into a suitable forum. ;)
maestrowing
phpBB.de User: maestrowing
phpBB.com User: maestrowing
Re: Adding a new group in Team Block - v.2.0.0b1
Post by maestrowing »
Hello,
I followed this guide completely and run, now I see the block groups are in my portal but see no members in it.
So I see only the group name in the portal block.
Any ideas what I might have done wrong, or there are other files should be edited?
robra
Post by robra »
maestrowing wrote:Hello,
What is the URL of your Forum ?
[]. Image
