Artodia: Mobile and SEO (Base: prosilver)
Style: Artodia: Mobile and SEO
Style Version: 2.0
Style Download: http://www.phpbb.com/customise/db/style ... er_mobile/
This style only works with subsilver2-portal-file!!!
to: root/styles/art_mobile/template/portal/*.*
to: root/styles/art_mobile/theme/images/portal/*.*
open: root/styles/art_mobile/template/overall_footer.html
open: root/styles/art_mobile/template/overall_header.html
<li><a href="{U_INDEX}">{L_INDEX}</a></li>
<li><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a><!-- ENDIF --></li>
open: root/styles/art_mobile/template/portal/modules/forumlist.html
<!-- INCLUDE forumlist_body.html -->
open: root/styles/art_mobile/template/portal/portal_body.html
<td class="row1">
<td class="row1" style="border: solid 0px">
<td colspan="3">
<td colspan="3" style="border: solid 0px">
<td width="{S_PORTAL_LEFT_COLUMN}px" valign="top" style="padding-<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->left<!-- ELSE -->right<!-- ENDIF -->:{$BLOCK_DISTANCE};">
<td width="{S_PORTAL_LEFT_COLUMN}px" valign="top" style="padding-<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->left<!-- ELSE -->right<!-- ENDIF -->:{$BLOCK_DISTANCE}; border: solid 0px">
<td valign="top">
<td valign="top" style="border: solid 0px">
<td width="{S_PORTAL_RIGHT_COLUMN}px" valign="top" style="padding-<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->:{$BLOCK_DISTANCE};">
[code]<td width="{S_PORTAL_RIGHT_COLUMN}px" valign="top" style="padding-<!-- IF S_CONTENT_DIRECTION eq 'rtl' -->right<!-- ELSE -->left<!-- ENDIF -->:{$BLOCK_DISTANCE}; border: solid 0px">
[/code]
<td colspan="3">
open: root/styles/art_mobile/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<table class="tablebg" cellspacing="1" width="100%"><tr><th style="padding-top: 4px; padding-bottom: 3px;"><span style="float: left">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</span></th></tr></table>' -->
<!-- DEFINE $LR_BLOCK_F_R = '' -->
<!-- DEFINE $C_BLOCK_H_L = '<table class="tablebg" cellspacing="1" cellpadding="0" width="100%"><tr><th style="padding-top: 7px; padding-bottom: 4px;"><span style="text-align: center">' -->
<!-- DEFINE $C_BLOCK_H_R = '</span></th></tr></table>' -->
<!-- DEFINE $C_BLOCK_F_R = '' -->
<!-- DEFINE $BLOCK_DISTANCE = '3px' -->
Dieser Style funktioniert nur mit subsilver2-Portal-Dateien!!!
nach: root/styles/art_mobile/template/portal/*.*
nach: root/styles/art_mobile/theme/images/portal/*.*
Öffne: root/styles/art_mobile/template/overall_footer.html
Öffne: root/styles/art_mobile/template/overall_header.html
Öffne: root/styles/art_mobile/template/portal/modules/forumlist.html
Öffne: root/styles/art_mobile/template/portal/portal_body.html
<td class="row1">
<td colspan="3">
<td valign="top">
<td colspan="3">
Öffne: root/styles/art_mobile/template/portal/_block_config.html
