Style Version: 3.0.10.3
Style Download: http://www.phpbb.com/customise/db/style/wowmoonclaw/
to: root/styles/WoWMoonclaw/template/portal/*.*
to: root/styles/WoWMoonclaw/theme/images/portal/*.*
open: root/styles/WoWMoonclaw/template/breadcrumbs.html
open: root/styles/WoWMoonclaw/template/overall_header.htmlCode: Select all
<div id="menubar">
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> <span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF -->
</div> <div id="wrapcentre">
</table> <br />
Tip: Add these lines on a new blank line after the preceding line(s) to find.open: root/styles/WoWMoonclaw/template/portal/_block_config.htmlCode: Select all
<!-- Config for the left and right blocks //--> <!-- DEFINE $LR_BLOCK_H_L = '<table class="tablebg" cellspacing="1" width="100%"><tr><th style="padding-top: 7px; padding-bottom: 1px;"><span style="float: left">' --> <!-- DEFINE $LR_BLOCK_H_R = '</span></th></tr></table>' --> <!-- DEFINE $LR_BLOCK_F_L = '' --> <!-- DEFINE $LR_BLOCK_F_R = '<br />' --> <!-- Config for the center blocks //--> <!-- DEFINE $C_BLOCK_H_L = '<table class="tablebg" cellspacing="1" cellpadding="0" width="100%"><tr><th style="padding-top: 9px; padding-bottom: 5px;"><span style="text-align: center">' --> <!-- DEFINE $C_BLOCK_H_R = '</span></th></tr></table>' --> <!-- DEFINE $C_BLOCK_F_L = '' --> <!-- DEFINE $C_BLOCK_F_R = '<br />' --> <!-- Images-URL //--> <!-- DEFINE $WHOS_IMAGES = '/images/whosonline.gif' --> <!-- DEFINE $NO_AVATAR_IMG = '/images/no_avatar.gif' --> <!-- Vertical distance between left/right and center Blocks --> <!-- DEFINE $BLOCK_DISTANCE = '10px' --> <!-- show Icons in left/right Blocks? 0=no 1=yes --> <!-- DEFINE $S_BLOCK_ICON = 1 --> <!-- override the column width settings of the ACP for this style? 0=no 1=yes --> <!-- DEFINE $S_COLUMNS_WIDTH_OVERRIDE = 0 --> <!-- override the column width settings of the ACP - set the width if enabled --> <!-- DEFINE $PORTAL_LEFT_COLUMN_OVERRIDE = '200' --> <!-- DEFINE $PORTAL_RIGHT_COLUMN_OVERRIDE = '200' --> <!-- override for rtl styles ... only needed if you have an RTL language --> <!-- IF S_CONTENT_DIRECTION eq 'rtl' --> <!-- DEFINE $LR_BLOCK_H_L = '<table class="tablebg" cellspacing="1" width="100%"><tr><th><span style="float: right">' --> <!-- ENDIF -->
nach: root/styles/WoWMoonclaw/template/portal/*.*
nach: root/styles/WoWMoonclaw/theme/images/portal/*.*
Öffne: root/styles/WoWMoonclaw/template/breadcrumbs.html
Öffne: root/styles/WoWMoonclaw/template/overall_header.htmlCode: Select all
<div id="menubar">
FindenCode: Select all
</table> <br />
Hinweis: Diese Zeile(n) werden in einer neuen Zeile nach den/der gerade gesuchten eingefügt.Öffne: root/styles/WoWMoonclaw/template/portal/_block_config.htmlCode: Select all
