ExtremeDark Red (Base: prosilver)
Style: ExtremeDark Red
Style Version: 1.0.3
Style Download: http://www.phpbb.com/customise/db/style ... ark_red_3/
to: root/styles/extremedarkred/template/portal/*.*
to: root/styles/extremedarkred/theme/portal.css
to: root/styles/extremedarkred/theme/images/portal/*.*
open: root/styles/extremedarkred/template/overall_footer.html
<a href="{U_INDEX}" accesskey="h">
open: root/styles/extremedarkred/template/overall_header.html
<div id="navmenu">
			<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &nbsp;&#8226;&nbsp; <!-- ENDIF -->
<div id="content">
	<div id="page-body">
open: root/styles/extremedarkred/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/extremedarkred/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/extremedarkred/template/theme/colours.css
.bg1	{ background-color: #ECF3F7; }
.bg2	{ background-color: #2D2D2D;  }
.bg1	{ background-color: #232323; }
.bg2	{ background-color: #232323;  }
open: root/styles/extremedarkred/theme/stylesheet.css
open: root/styles/extremedarkred/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="rounded_corners_top"><div class="left" style="text-align: left; white-space: nowrap; width: 0px; padding: 8px 0 10px 25px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</div><div class="right"></div></div><div class="clear"></div><div class="forabg"><div class="inner"><ul class="topiclist"><li class="header"><dl class="icon"><dt>&nbsp;</dt></dl></li></ul><ul class="topiclist forums"><li class="row" style="padding: 0px 8px 5px;">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</li></ul></div></div><div class="rounded_corners_bottom"><div class="left"></div><div class="right"></div></div><div class="clear"></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="rounded_corners_top"><div class="left">' -->
<!-- DEFINE $C_BLOCK_H_R = '</div><div class="right"></div></div><div class="clear"></div><div class="forabg"><div class="inner"><ul class="topiclist"><li class="header"><dl class="icon"><dt>&nbsp;</dt></dl></li></ul><ul class="topiclist forums"><li class="row" style="padding: 0px 8px 5px;">' -->
<!-- DEFINE $C_BLOCK_F_R = '</li></ul></div></div><div class="rounded_corners_bottom"><div class="left"></div><div class="right"></div></div><div class="clear"></div><br style="clear:both" />' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="rounded_corners_top"><div class="left">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</div><div class="right"></div></div><div class="clear"></div><div class="forabg"><div class="inner"><ul class="topiclist"><li class="header"><dl class="icon"><dt>&nbsp;</dt></dl></li></ul><ul class="topiclist forums"><li class="row" style="padding: 0px 8px 5px;">' -->
<!-- DEFINE $S_POSTBODY_TOP = 0 -->
nach: root/styles/extremedarkred/template/portal/*.*
nach: root/styles/extremedarkred/theme/portal.css
nach: root/styles/extremedarkred/theme/images/portal/*.*
Öffne: root/styles/extremedarkred/template/overall_footer.html
Öffne: root/styles/extremedarkred/template/overall_header.html
<div id="navmenu">
<div id="content">
Öffne: root/styles/extremedarkred/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/extremedarkred/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/extremedarkred/template/theme/colours.css
Öffne: root/styles/extremedarkred/theme/stylesheet.css
Öffne: root/styles/extremedarkred/template/portal/_block_config.html
