After updating from v 1.0.6 to 2.0.0b1 my portal dissappeared.
You can see what's wrong on my site:
http://www.schoolviane.be/portal.php
I have the SpringElement Style installed so I thought this could be the problem, however when I changed the theme to Prosilver (I've updated the Prosilver files aswell) I've got the same problem.
I also have phpBB Gallery 1.1.4 installed.
While installing (upgrading) I've got no errors but I did get a warning I should check my permissions since some of them were changed.
Can somebody resolve this problem?
Thanks!
Portal gone after upd from 1.0.6 to 2.0.0b1
Re: Portal gone after upd from 1.0.6 to 2.0.0b1
Then you must check the permission, who can see the portal.Robindr wrote: http://www.schoolviane.be/portal.php
I have looked for the permissions for the portal in the acp, but I can't find it?
How would I change the permissions?
In ACP => Permissions => User Roles => Miscellaneous.
In ACP => Permissions => Administrator roles => Miscellaneous.
You must click on the green button.
Archivar, tut mir Leid (that's all I know in German ) but I don't see where I can change these settings for the portal. Maybe I'm blind or just plain stupid, but I don't find it....
This is what I see when I click the admin role Standard Admin green button.
http://www.schoolviane.be/acp_admin_role.jpg
And can the portal made visible to guests? And how would I do that?
In ACP => Permissions => User Roles => Misc.
Weird it just isn't working for me
Now I have found the "Can view the portal" and I've put this to "Yes" but still I (as an admin) can't see the portal. I've set it to yes for guests aswell, but when I logout I can't see the portal as a guest either...
I suppose this is where I should set the permissions:
http://www.schoolviane.be/acp2.jpg
As you can see I've set it correctly. Still no portal....
Whoohoo problem solved it appears. I've purged the cache and it is working!!
Yes!!
Thanks archivar!! Du bist super !! Lol
Yes!!
