Aero / *7 colors available (Base: prosilver)
Style: Aero / *7 colors available. Blue, Black, Red, Green, Pink, Purple, and Teal.
Style Version: 1.5.0
Style Download: http://www.phpbb.com/community/viewtopi ... 4&t=639995
This Guide is written for AeroBlue, but it works for AeroBlack, AeroRed, AeroGreen, AeroPink, AeroPurple and AeroTeal also.
If you want to use this Guide for ..Black ..Green or ..Purple you just have to replace "Aero" with the Name of your Style in this Guide.
to: root/styles/Aero/template/portal/*.*
to: root/styles/Aero/theme/portal.css
to: root/styles/Aero/theme/images/portal/*.*
open: root/styles/Aero/template/overall_header.html
    <td class="tl"></td>
    <td class="tm"></td>
    <td class="tr"></td>
    <td class="ml"></td>
    <td class="navbar">
<a href="{U_INDEX}" accesskey="h"><b>{L_INDEX}</b></a>
<!-- IF U_PORTAL --><a href="{U_PORTAL}" accesskey="h"><b>{L_PORTAL}</b></a> &#187; <!-- ENDIF -->
				</li>
 {$A_BLOCK_END}
open: root/styles/Aero/template/overall_footer.html
open: root/styles/Aero/template/portal/modules/login_box_side.html
<a href="{U_LOGIN_LOGOUT}">
<a class="genmedw" href="{U_LOGIN_LOGOUT}">
open: root/styles/Aero/template/portal/modules/whois_online_center.html
<a href="{U_VIEWONLINE}">
<a class="genmedw" href="{U_VIEWONLINE}">
open: root/styles/Aero/template/portal/modules/whois_online_side.html
open: root/styles/Aero/theme/stylesheet.css
open: root/styles/Aero/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr><td class="tl"></td><td class="tm"></td><td class="tr"></td></tr><tr><td class="ml"></td><td><div class="cat"><ul class="topiclist"><li class="header"><dl class="icon"><dt style="padding: 3px 0px 2px; white-space: nowrap;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul></div><ul class="topiclist forums"><li><dl><dd style="border-left: 0px; width: 100%;"><div style="text-align: left; margin: 0px 5px 0px 5px;">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</td><td class="mr"></td></tr><tr><td class="bl"></td><td class="bm"></td><td class="br"></td></tr></table>' -->
<!-- DEFINE $C_BLOCK_H_L = '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr><td class="tl"></td><td class="tm"></td><td class="tr"></td></tr><tr><td class="ml"></td><td><div class="cat"><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $C_BLOCK_H_R = '</dt></dl></li></ul></div>' -->
<!-- DEFINE $C_BLOCK_F_R = '</td><td class="mr"></td></tr><tr><td class="bl"></td><td class="bm"></td><td class="br"></td></tr></table>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr><td class="tl"></td><td class="tm"></td><td class="tr"></td></tr><tr><td class="ml"></td><td><div class="cat"><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</dl></li></ul></div>' -->
<!-- DEFINE $BLOCK_DISTANCE = '0px' -->
additional changes: viewtopic.php?f=36&t=10393&p=33948#p33948
Diese Anleitung wurde für AeroBlue geschrieben, funktioniert aber auch für AeroBlack, AeroRed, AeroGreen, AeroPink, AeroPurple und AeroTeal.
Wenn ihr diese Anleitung für ..Black ..Green oder ..Purple nutzen wollt, müsst ihr einfach "Aero" in dieser Anleitung mit dem Namen eures Styles ersetzen.
nach: root/styles/Aero/template/portal/*.*
nach: root/styles/Aero/theme/portal.css
nach: root/styles/Aero/theme/images/portal/*.*
Öffne: root/styles/Aero/template/overall_header.html
    <td class="navbar">
				</li>
 {$A_BLOCK_END}
Öffne: root/styles/Aero/template/overall_footer.html
Öffne: root/styles/Aero/template/portal/modules/login_box_side.html
Öffne: root/styles/Aero/template/portal/modules/whois_online_center.html
Öffne: root/styles/Aero/template/portal/modules/whois_online_side.html
Öffne: root/styles/Aero/theme/stylesheet.css
Öffne: root/styles/Aero/template/portal/_block_config.html
zusätzliche Änderungen: viewtopic.php?f=36&t=10393&p=33948#p33948
Reason: 1.)Fehler in der login_box_side.html-2.)Anleitung für Style Version: 1.5.0 geändert
