Your Portal Version: 1.0.6
Boardlink: http://www.godhra.org
I searched in this forum, and I also clicked on Knowledge base but could not find any topics related to my subject.
I tried modifying various margin padding values in the portal.css, but no luck.
There is too much blank spacing between blocks on all left, right, and center blocks. I would like to keep the blocks close to each other with a very thin line of spacing.
Can anyone out there help fix this issue.
Thanks.
How to reduce spacing between blocks on portal
ishaqkalota
- phpBB.com User: ishaqkalota
Re: How to reduce spacing between blocks on portal
Search in root / styles / prosilver / template / portal / _block_config.html:ishaqkalota wrote:Your Portal Version: 1.0.6
Thanks.
Removed at the end of line 6 and line 12
<br style="clear:both" />V.G. archivar
ishaqkalota
Thank you so much! That worked like a charm!..
