Your Portal Version: 1.0.6
Boardlink: http://forumdubateau.com
I have try to change my .htaccess (generated by phpBB SEO) with the line :
in this case it's impossible to acccess. I have an error 500
I didnt find solutions
I cannot open directly on Portal
firebird
Re: I cannot open directly on Portal
Ask your web-hosting provider.firebird wrote:Your Portal Version: 1.0.6
firebird
Indeed, it is about a problem with my provider.
It accpet only DirectoryIndex index.php index.html
If someboby have a solution for circumvent the problem, it's fantastic
