Logout redirect
Logout redirect
Hi, what is necessary to do to have redirect after logout to portal page (instead to index page)?
Thanks
Thanks
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
Re: Logout redirect
Hm, I guess you have to modify your .htaccess-file (in forum-root) about like this:JirkaX wrote:Hi, what is necessary to do to have redirect after logout to portal page (instead to index page)?
Thanks
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
Re: Logout redirect
Nah, you have to edit a specific file. I'll find it for you, I just got home.
Re: Logout redirect
Edit ucp.php
Find - Line 95
Open styless/*/template/portal/block/user_menu.php
Should work.
Find - Line 95
meta_refresh(3, append_sid("{$phpbb_root_path}index.$phpEx"));
$message = $message . '<br /><br />' . sprintf($user->lang['RETURN_INDEX'], '<a href="' . append_sid("{$phpbb_root_path}index.$phpEx") . '">', '</a> ');
$portal_logout = request_var('portal_logout', 0);
if( !$portal_logout )
$redirect_link = append_sid("{$phpbb_root_path}index.$phpEx");
} else {
$redirect_link = append_sid("{$phpbb_root_path}portal.$phpEx");
meta_refresh(3, $redirect_link);
$message = $message . '<br /><br />' . sprintf($user->lang['RETURN_INDEX'], '<a href="' . $redirect_link . '">', '</a> ');
{U_LOGIN_LOGOUT}
{U_LOGIN_LOGOUT}&portal_logout=1
Re: Logout redirect
Unfortunately doesn't work, redirect is still to the index.php
Re: Logout redirect
Try
} else {
Re: Logout redirect
Now when I perform logout on portal page, I'm redirected to portal page, when I perform logout on board index page, I'm redirected to board index page. Is it possible to be redirected to portal page every time? If so, should I change code below
to
} else {
Re: Logout redirect
Yeh just remove the changes I did and replace index with portal.
Re: Logout redirect
Great. And one last question - is it possible to modify redirect to go to last page where user clicked on logout?
Re: Logout redirect
You'd have to make quite a few changes to the logout script, for that you'd have to fiddle with it yourself I'm afraid.
Re: Logout redirect
Ok, I will try it. Thanks for your help.
