[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 665: Invalid argument supplied for foreach()
function bbcode_second_pass_eftfitting($export)
global $db;
$fitdetails = explode("\n",trim($export));
foreach($fitdetails as $key=>$row){
if($key == '0'){
$titlebits = explode(',',preg_replace('/(\[|\])/','',$row));
$shipType = $titlebits[0];
$name = trim($titlebits[1]);
continue;
$fitting_array[] = $row;
//Start fitting
$fitting_output = '<div id="fittitle"><h3>'.$name.'</h3><h4>'.$shipType.'</h4></div>';
$fitting_output .= '<div id="fitting_container">';
$fitting_output .= '<div class="fitting_tabs"><ul class="fit-tabs"><li class="fit-tab" onclick="chooseTab(this,\'loadout\');">Loadout</li><li class="fit-tab" onclick="chooseTab(this,\'export\');">EFT Export</li></ul><div style="clear:both;"></div></div>';
$fitting_output .= '<div id="fittext" style="display:none;">' .$export . '</div>';
$fitting_output .= '<div title="fitting" id="fitting">';
//Fitting window
$fitting_output .= '<div id="fittingwindow"><img border="0" alt="" src="images/fitting/fitting2.png"></div>';
$sql = 'SELECT * FROM EFTShips WHERE typeName="'.$shipType.'"';
$shipdetails = $db->sql_fetchrow($result);
$fitting_output .= '<div id="shipicon"><img border="0" alt="" title="'.$shipType.'" src="http://image.eveonline.com/InventoryType/'.$shipdetails['TypeID'].'_64.png"></div>';
$sql = 'SELECT DISTINCT location FROM EFTmodules';
while($row = $db->sql_fetchrow($result))
$position[$row['location']] = 1;
//Produce fit display
foreach($fitting_array as $itemname){
//ignore blank lines
if($itemname =='')
continue;
if(strpos($itemname,',')){
$details = explode(',',$itemname);
$itemname = $details[0];
//get the info about the module
$sql = 'SELECT typeID, location FROM EFTmodules where TypeName = "' . $itemname . '"';
$fitting_output .= '<div id="'.$row['location'].$position[$row['location']].'"><img border="0" title="'.$itemname.'" src="http://image.eveonline.com/InventoryType/'.$row['typeID'].'_32.png"></div>';
if(!empty($details[1])){
$charges[$row['location']][$position[$row['location']]] = trim($details[1]);
unset($details);
//increment the position
$position[$row['location']]++;
if(is_array($charges)){
foreach($charges as $slot=>$positions){
foreach($positions as $position=>$itemname){
if(!empty($itemname))
$result = $db->sql_query('SELECT typeID FROM EFTCharges where TypeName = "' . $itemname . '"');
$fitting_output .= '<div id="'.$slot.'charge'.($position).'"><img border="0" title="'.$itemname.'" src="http://image.eveonline.com/InventoryType/'.$row['typeID'].'_32.png"></div>';
for($i = ($position[$row['location']]);$i < $shipDetails[$row['location']];$i++){
$fitting_output .= '<div id="'.$row['location'].($i+1).'"><img border="0" title="Empty '.ucfirst($row['location']).' Slot" src="images/fitting/'.$row['location'].'.png"></div>';
//End fitting
$fitting_output .= '</div></div>';
return($fitting_output);
Im normalen Forum läuft es fehlerfrei
hier ist mal der link zum portal http://www.elve-industries.de
Ich denke mal das es nur ne Kleinigkeit ist. Wäre nett wenn da mal nen Portal Profi was zu sagen könnte.
