Your Portal Version: 1.0.6
Boardlink: http://46.236.2.245/jerre
PHP Version: 3.0.9
Nothing, the problem was always there
Checked the installation files, browsed the web for solutions.
Hello,
I've been testing stuff related to phpbb on my test-site, before I put it on my actual website.
I installed Board3, but I'm having a minor problem.
When I go to my (test-) forum, the portal isnt the index. I go directly to the forum itself, and not to the portal.
Did I forgot something during the installation?
Thanks in advance,
Jerree.
Portal isnt the index
Jerree
Jerree
Re: Portal isnt the index
Nevermind, it was a problem with apache2 not being able to read .htaccess files. It's all fixed now
Tnx.
Tnx.
