Is there any chance that you guys would be able to convert a star wars PHPBB3 theme for us?
I do like this one here; http://swtor.markupworks.com/viewtopic.php?f=5&t=18 But after seeing another thread not sure if it can be done.
However, if there are any similar nice Star Wars themes, it'd be great to see one done!
Thanks,
SWTOR Theme?
- phpBB.de User: justjon
- phpBB.com User: justjon
Re: SWTOR Theme?
Anyone?
- Translator
- phpBB.com User: Anywhere91
Re: SWTOR Theme?
Can you give a download link?
Regards
Regards
Re: SWTOR Theme?
Here is a download link : http://www.bbdkp.com/downloads.php?view=detail&df_id=44
Here is a forum where ppl are working on the theme: http://www.bbdkp.com/viewtopic.php?f=15&t=2111
I hope you can help with this since SWTOR already have 1.7KK accounts sold and will be the BIGGER AND BETTER mmorpg ever !!
- Translator
Re: SWTOR Theme?
Hello / good evening
This style works with heritage "prosilver"
Just apply the changes to the style requested by the install.xml file.
So,
Sorry for my bad english ! I'm just french
So,
- Modify the template/overall_header.html, template/overall_footer.html and theme/stylesheet.css files
- Then, on your site "SWTOR" creates the directory in the directory styles / (or the folder is located prosilver)
- Uppload your files in the directory you just created and the files of the portal to put in the "Template"
- ACP / Styles / Enable style
- Enjoy
