Moving portal.php outside of your forums directory?
Current Version: 2.0.2
Released: 2013-10-27
victory1
Post by victory1 »
I'm finally thinking of updating to the new version. I used the knowledge base to move my portal.php outside my forums directory the day I stall my portal. Will the instructions for this version be the same?
alicia
phpBB.com User: Alicia86
Re: Moving portal.php outside of your forums directory?
Post by alicia »
I've been holding off upgrading to the newest version (even if it is a beta) since ATM it seems impossible to us the portal as a site index.
Any plans to implement this?
victory1
Post by victory1 »
Hello, instead of ignoring this valid question, could someone at least tell me if can be done? I have quite a few links in other websites with the portal.php outside of the forums. In of course with search engines such as Google. Thanks
victory1
Post by victory1 »
Never-mind. :) Thanks
alicia
Post by alicia »
victory1 wrote:I figured it out. thanks
If you got it working would you mind sharing with the rest of us? :lol:
alicia
Post by alicia »
Sorry Victory. They have me still as a newly registered user and cannot reply to your PMs. I did get it.
Castiel
Post by Castiel »
I'm very curious about the methods used to accomplish this as well. I currently have version 1.0.6 with the portal set up outside the forum directory. In order to upgrade to 2.0, this is something I'd definitely need to know. Any help would be vastly appreciated :)
victory1
Post by victory1 »
Here are the directions to move portal outside the forums directory. I decided to share it since I've had several PMs of people wanting me to share this.
Move
/forums/portal.php to /portal.php.
Open /forums/.htaccess
REMOVE :
Open /portal.php
Find :
Replace with :
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './forums/';
This change from the previous version:
Open /forums/includes/functions.php
Find :
'U_PORTAL'				=> (isset($config['board3_enable']) && $config['board3_enable'] && $auth->acl_get('u_view_portal')) ? append_sid("{$phpbb_root_path}portal.$phpEx") : '',
Replace with :
'U_PORTAL'				=> (isset($config['board3_enable']) && $config['board3_enable'] && $auth->acl_get('u_view_portal')) ? append_sid("../portal.$phpEx") : '',
Open :
/forum/portal/modules/announcements.php
/forum/portal/modules/news.php
/forum/portal/modules/stylechanger.php
/forum/portal/modules/calendar.php
/forum/portal/modules/poll.php
/forum/portal/modules/user_menu.php
Find :
Replace with :
portal.$phpEx
This is new to make work with 2.0.0 :
Open :
/Forums/portal/includes/functions.php
Find :
		include(PORTAL_ROOT_PATH . 'includes/trim_message/trim_message.' . $phpEx);
Replace with :
		include($phpbb_root_path . 'includes/trim_message/trim_message.' . $phpEx);
Find :
		include(PORTAL_ROOT_PATH . 'includes/trim_message/bbcodes.' . $phpEx);
Replace with :
		include($phpbb_root_path . 'includes/trim_message/bbcodes.' . $phpEx);
Mess
phpBB.com User: Mess
Post by Mess »
Thanks victory1
