calendar mod 1.0.0b3+ and board3_portal_2_0_0b1
I installed calendar mod 1.0.0b3+ and board3_portal_2_0_0b1 and tried to follow the directions to put the topic calendar block on the board3 portal page. The first instructions says to open portal/block/additional_blocks.php. I do not have this file in that directory, only calendar.php. Any ideas?
Re: calendar mod 1.0.0b3+ and board3_portal_2_0_0b1
portal v. 2.x.x is completly different than previous. SO you need to develop your own block, or wait, until someone will.
Je?d??: T3 '86 1.6D (CS) -> 1.7D (KY) -> 1.9TD (AAZ) + 3H
Trzeba my?le? praktycznie, dopóki nie przyjdzie czas, ?e mo?na ju? zacz?? my?le? niepraktycznie.
busomania.pl
- phpBB.de User: cwjs
- phpBB.com User: cwjs
I really like this portal, I use calendar mod 1.0.0b3+ too, but I know that Stuart is not supporting it anymore.
I hope someone can this on, I am not happy with the method for creating events in the calendar block that comes with this portal, I have a non-admin that manages the calendar.
