Addon: Quick Title Edition for B3P v2.0.0
Addon Version: 1.0.2
Addon Author: WileCoyote
Addon Description:
This addon will allow users to use the MOD Quick Title Edition v1.1.0 on Board3 Portal 2.0.0
Addon Requirements: Board3 Portal v2.0.0 and Quick Title Edition v1.1.0 by ABDev
Addon Download: here
Instructions:
Upload the package with Automod or edit required files manually
Author Notes: Automod installation will not work if Forum Title Colour for B3P v2.0.0 or/and Topic Title Colour for B3P v2.0.0 are already installed
IMPORTANT NOTICE: All "Quick Title Edition" related Addons are now developed by geolim4. So please don't ask me for updates
[ABD] Quick Title Edition for B3P v2.0.0
WileCoyote
- phpBB.de User: WileCoyote
- phpBB.com User: WileCoyote
lg,
WileCoyote
________________________________________
Get some German MOD Translations at
wu-systems.at - An Austrian phpBB Community
WileCoyote
WileCoyote
Re: [Release] Quick Title Edition for B3P v2.0.0
Addon updated for the B3P v2.0.0 Release
lg,
WileCoyote
WileCoyote
ixl
- Sponsor
- phpBB.de User: IXL
- phpBB.com User: IXLUKCOM
Can you please explain what this actually does in more detail please? I am not sure what its supposed to do and doesnt make much sense...
WileCoyote
As you can see in the first posting, this addon requires the Quick Title Edition Mod to be installed. Look at the description of this mod and you will know what this addon will do after it is installed.
lg,
WileCoyote
WileCoyote
ixl
- Sponsor
Just seems unnecessary to have to have to read a link to another site, when it could be explained in this one, thats all.
Shorty1968
- Portal Enthusiast
Hallo ich habe alle änderungen in den styles/prosilver/template/portal/modules/announcements_center.html, styles/prosilver/template/portal/modules/announcements_center_compact.html, gemacht aber bei den Globalen Ankündigungen wird das Prefix nicht angezeigt?
WileCoyote
In der Installationsanweisung ist ein kleiner Fehler:
Öffen portal/modules/portal_announcements.php
Finde
Ersetze mit
Die Zeile kommt 2x vor und muß auch 2x ersetzt werden.
Finde
$template->alter_block_array('announcements_row', array(Code: Select all
$template->alter_block_array('announcements_center_row', array(lg,
WileCoyote
WileCoyote
Shorty1968
- Portal Enthusiast
Hallo bei mir kommt die Zeile zwar nur 1x vor aber nun geht es danke.
WileCoyote
Wenn sie nur 1x vorkommt, hast du einen Einbaufehler
lg,
WileCoyote
WileCoyote
Shorty1968
- Portal Enthusiast
Hast recht es hat etwas gefehlt,aber es hatte dennoch Funktioniert?
MOB
- phpBB.com User: M.O.B.
