In the 1.0.6 - > 2.0.0b1 I've got an error:
Board3 Portal
PHP Version: 5.2.17
DBMS: MySQL(i) 5.0.90-log
phpBB3 Version: 3.0.9
Desconhecido
SQL ERROR Table 'goldtugagolden.golden_portal_modules' doesn't exist
Cheers
EDIT: I have update manually, not with automod.
EDIT2: Problem solved! I've uninstall... And try to install again. And it worked! But I want to know the solution... 'cause with this method I lost all my data ^^ (luckely I have a forum backup running aside :p)
