Missing css data for custom modules?
Current Version: 2.0.2
Released: 2013-10-27
intempest
phpBB.de User: intempest
phpBB.com User: intempest
Post by intempest »
http://feelthecrowd.com/connect/portal.php
I'm wondering if there is a missing CSS style sheet for board3 portal vs
I'm noticing on my center blocks the background in the blocks stay a dark black color that I don't believe is inherited from the style seeing as there are other blocks that look great. I went back through the install.xml and i don't believe i missed anything with the installation of the current style. But the same color bleed happens on prosilver too. So i'm not sure if there is a file missing or what is going on.
Re: Missing css data for custom modules?
intempest wrote:http://feelthecrowd.com/connect/portal.php
See install.xml.
portall.css integrate in the stylesheet.css.
intempest
Post by intempest »
Ahh, I did miss something...
You are a most wise php guru and i am humbled.
**not sarcasm, i really was stumped at that**
