sorry for my english...
I tryed to install this board in my phpbb 3.0.9 forum.
All the time the installer reports to me that can't create a table. ( a lazy installer ? hahaha
So i tried to create it all by myself, usign the error listed every time...
At the end of the process it says: "completed"
I see all in my acp panel, but i don't see anything in in my forum.
Maybe I made some error creating this table or maybe the error is somewhere else...
Can someone tell me wich is the sql structure for the phpbb_portal_modules ?
Or if there is a simple way to install this great portal ?
(i also tried to install an old version and make an update to this release, but the error is always the same)
Thanks!
[EDIT]
I searched inside all the php file, until I found this:
'table_add' => array(
array(PORTAL_MODULES_TABLE, array(
'COLUMNS' => array(
'module_id' => array('UINT:3', NULL, 'auto_increment'),
'module_classname' => array('VCHAR:64', ''),
'module_column' => array('TINT:3', 0),
'module_order' => array('TINT:3', 0),
'module_name' => array('VCHAR', ''),
'module_image_src' => array('VCHAR', ''),
'module_image_width' => array('INT:3', 0),
'module_image_height' => array('INT:3', 0),
'module_group_ids' => array('VCHAR', ''),
'PRIMARY_KEY' => 'module_id',
I don't know why the installer won't create only this table, i tried a lot of times also beginning from zero and the result was always the same...
