Hi, I have this problem:
- when user is not logged in, he can see portal without any problem
- when user is logged in, he does not see portal (only standard forum) and when he adds url with portal.php, he is automatically forwarded to index.php
- I (as a admin) see portal without any problem
This happends after update to 2.0.
Could yoiu help me with that?
Thanks
Problem - portal visibility
Re: Problem - portal visibility
Did you set the permissions correctly?
Frankly speaking I thought so, but now I am not sure .... how to check it easily?
Hi, any ideas? Permissions for all modules of the portal are set for all users. Is there any option to set permission for portal itself? If not, I have no any idea how to start it working ...
Put them on the Rights of the groups rather than individual users.JirkaX wrote:Hi, any ideas? Permissions for all modules of the portal are set for all users. Is there any option to set permission for portal itself? If not, I have no any idea how to start it working ...
You can better manageable.
And check the user's roles.
Thanks, I forgot to set permissions in phpBB permissions menu.
