Boardlink: http://yorstarkaraoke.hostei.com/portal.php
Hello all, After a 2 year time out I am returning to my website. 2 years ago I was able to change the navigation link text to Forums/Arcade. However I cannot for the life of me figure out how. I did not edit the Overall_Header Main menu html or links.HTML files to do this. I think I may have changed the definition of {u_Index} or such. If someone could visit my portal and check the source code maybe you can help me narrow it down. I searched this forum high and low for 2 days. And have checked my template files and tons others with my ftp and I can't figure it out.
I thought it had to be an HTML file but I have overlooked every one of them several time. 2 years off its amazing what one forgets lol. Anyways thanks in advance. Whatever you need to help me out I will do for you. Thanks much
Regards
Navigation Link text
Re: Navigation Link text
open: root/styles/prosilver/template/portal/block/main_menu.html
<li><a href="{U_INDEX}">{L_INDEX}</a></li>Tip: Add these lines on a new blank line after the preceding line(s) to find.
<li><a href="{U_ARCADE}">{L_ARCADE}</a></li>V.G. archivar
thraxx
sorry for long delay in my reply I have been busy setting up on a new domain etc. Thanks for the reply
I got it working great now.
