I have recently installed Board3 Portal 2.0.0b1 (PhpBB3 2.0.8) and it all works great. I am now trying to add in an additional custom block but the procedure I used to follow in the guidelines at knowledge/kb_show.php?id=51) no longer seems to apply in this version?
Any chance of an update for 2.0.x on what we now need to do with this new version?
Creating Custom Blocks (2.0.x)
Bagpuss
playagiron
Re: Creating Custom Blocks (2.0.x)
no, it's completely changed AFAIK.
But here is a description of how to create Blocks:
knowledge/kb_show.php?id=55
Also, you can edit existing ones or take them as template for your own block:
knowledge/kb_show.php?id=54
It is really nice and very clean, much more straightforward than in 1.0.6!
