Space between blocks / Title background image
Current Version: 2.0.2
Released: 2013-10-27
playagiron
Post by playagiron »
Hi there,
great new release the beta of 2.0.0, really much more practical to edit one's portal!
Just have two small questiosn coming from 1.0.6
1) The space between two side blocks seems to have increased in the new version. As it is done by using <br style="clear:both">, I find it not obvious to change its heigth. Any chance to make this a user option or how it could be easily changed via CSS?
2) The background colour/image of the side blocks used to be the same as the backgroud colour (prosilver), while now it is the same as the header of threads in the forum view. IMHO it gives the portal a very diferent look. While I am not sure what I prefer, might this also be user editable?
Finally, a bug concerning the non-parsing of image size for user blocks (see another post) would be great to be fixed in the final release.
But really awesome work!! Looking forward to the 2.0.0 final release!
Re: Space between blocks / Title background image
1) This hasn't changed between 1.0.6 and 2.0.0b1.
2) This can be changed in _block_config.html. You would have to adapt the 1.0.6 block config for 2.0.0b1. I'm not sure if archivar would be willing to do this.
playagiron
Thanks a lot! Works like charm!
indeed easy to modify! Great coding!!
