I converted from 1.0.6 to the latest beta version of 2.0.x, While in the installer, i came across this error message:
Converting from Board3 Portal 1.0.6 & adding basic set of modules
SQL ERROR Table 'racecreations.phpbb_portal_modules' doesn't exist
So how do i manually add this to my Data base?
Converting from 1.0.6 Install error
Re: Converting from 1.0.6 Install error
make sure you read
one edit is quite essential to fix your problem
/contrib/update_106_to_200b1/update.xml
Greetings to all.
I just do the conversion from version 1.0.6 to version board3_portal_2_0_0b1.
I carefully followed the steps of editing /contrib/update_106_to_200b1/update.xml
But when installing, I get the following errors.
Now the board3 portal does not work on my website.
Do not know how to fix it so I appreciate your help.
What information should be facilitated so that I can help?
Thanks
(Sorry for me bad English).
Thanks
