What is Board3 Portal 2.0.0?
Board3 Portal 2.0.0 is the next major version of Board3 Portal.
What has been changed in Board3 Portal 2.0.0?
For Version 2.0.0 the complete base of Board3 Portal has been rewritten. Unfortunately this also means that no previous Add-ons will work with Board3 Portal 2.0.0.
There are also a few changes and new features in Board3 Portal 2.0.0:
- Modules can be moved via the ACP - no need to edit any files
- Unlimited custom blocks - you can add as many custom blocks in the ACP as you want
- New modules like the Gallery Block can be added without any edits
- Better performance - a new Portal now only needs around 30 Queries (1.0.x needed over 50)
- Event feature in calendar module
- Upload modules via the ACP
What are the requirements for Board3 Portal 2.0.0?
Board3 Portal 2.0.0 has the same requirements as phpBB 3.0.x.
Additionally you will also need PHP5.
Where can I download Board3 Portal 2.0.0?
You can download it here: http://board3.de/viewforum.php?f=40
Can I update Board3 Portal 1.0.x to Board3 Portal 2.0.0?
Yes. The update was written for Board3 Portal 1.0.6. Older version will have to be updated to 1.0.6 first and then you can convert it to Board3 Portal 2.0.0.
