proVacation
proVacation
This config works for both Styles / Diese Konfiguration funktioniert für Styles: proVacation v. 3.0.8
_block_config.html
<!--version $Id: _block_config.html v1.0.6 adapted by: archivar $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="categories_haut_bloc"><div class="categories_haut-gauche"></div><div class="categories_haut-centre"><div style="text-align: center" class="categories_texte">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</div></div><div class="categories_haut-droit"></div></div><div class="categories_bordure_bloc"><div class="categories_bordure_gauche"><div class="categories_bordure_droit"><div class="categories_contenu"><div class="inner"><span class="corners-top"><span>&nbsp;</span></span>' -->
<!-- DEFINE $LR_BLOCK_F_R = '<span class="corners-bottom"><span>&nbsp;</span></span></div></div></div></div></div><div class="categories_base_bloc"><div class="categories_base-gauche"></div><div class="categories_base-centre"></div><div class="categories_base-droit"></div></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="categories_haut_bloc"><div class="categories_haut-gauche"></div><div class="categories_haut-centre"><div style="text-align: center" class="categories_texte"><dl>' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></div></div><div class="categories_haut-droit"></div></div><div class="categories_bordure_bloc"><div class="categories_bordure_gauche"><div class="categories_bordure_droit"><div class="categories_contenu"><div class="inner"><span class="corners-top"><span>&nbsp;</span></span>' -->
<!-- DEFINE $C_BLOCK_F_R = '<span class="corners-bottom"><span>&nbsp;</span></span></div></div></div></div></div><div class="categories_base_bloc"><div class="categories_base-gauche"></div><div class="categories_base-centre"></div><div class="categories_base-droit"></div></div><br style="clear:both" />' -->
viewtopic.php?f=47&t=4470
