Maroon Fusion?
CrashTester
Maroon Fusion?
Hi, is it possible to get Maroon Fusion done for Portal3 ? Many thanks!
Re: Maroon Fusion?
Yes,CrashTester wrote:Hi, is it possible to get Maroon Fusion done for Portal3 ? Many thanks!
the style is based on "subsilver2".
CrashTester
Re: Maroon Fusion?
Thanks. Not sure i understand what I am supposed to do then. Maroon Fusion is installed yet when its used the portal blocks are not shown (ie, left and right columns). Am I supposed to do something else with the style? Does it not need adapting at all?
Thanks.
Thanks.
Re: Maroon Fusion?
We ask for your attention:
CrashTester
Re: Maroon Fusion?
For the style you can take this guide:CrashTester wrote:Sure, link is; http://www.phpbb.com/customise/db/style/maroon_fusion/
portal_docs/contrib/subsilver2.xml
