Spanish characters in portal
rickszyr
phpBB.de User: rickszyr
phpBB.com User: rickszyr
Post by rickszyr »
Boardlink: http://forum.noentiendounpomo.com
Translated the portal to spanish
I don't even know where to start
characters like 'á é í ó ú' are displayed like ???. How can i fix that?
Re: Spanish characters in portal
Make sure your files are saves as UTF8 without BOM and not as ASCII.
rickszyr
Post by rickszyr »
How do i do that? =)
Use an editor like notepad++ (not the windows notepad). Then just convert the encoding to utf8 without bom. Afterwards save the file and upload it to your server and it should work.
rickszyr
Post by rickszyr »
Hi again, what files should I convert?
All files until it is fixed. ;)
rickszyr
Post by rickszyr »
Hi marc, for some reason I am unable to convert to UTF-8 without bom. It won't let me, not with notepad ++, or UTFCast, or anything. if I put "convert to UTF-8 without BOM" it just does nothing after saving. Any ideas, or tips? Could you post the php files in that encoding? Thank you!
purzl
Post by purzl »
I had similar Problems with a German Dialekt that I try on localhost for a Touristboard, I tried konvert my Lang files with Notepad++ and it works fine
That´s all Folk´s
