Boardlink: http://www.greyspace.ca/phpBB3/
no problem
re-checked site and similar threads
I hope this gets to you before you approve my previous post. I've since tried copying the /style/proSilver/template/portal/stuff.here into /style/formell/template/portal folder here. This because I added proFormell after installing Board3. I then went to ACP and made formell the default in settings and also in my control panel. All seems to work except that there is no "Portal" link next to and before "Board Index". So navigating back is an issue. I used the autoMod installer and apparently there are some files that have to be edited outside of it such as .htaccess which I figured out on my own
Next I'll have a look in portal_body.html inside the newly copied portal folder in proFormell. Am I on the right track here?
What do you mean in other similar posts regarding "you have to run the proSilver stuff in Formell".
Much thanks in advance.
