This is a copy of mike's overall_header.html:
<head>
<meta name="copyright" content="2002-2006 phpBB Group" />
{META}
<style type="text/css">
/*Credits: CSSplay */
/*URL: http://www.cssplay.co.uk/menus/pro_drop2 */
.preload2 {background: url(prodrop2/button4.gif);}
.menu2 {padding:0 0 0 32px; margin:0; list-style:none; height:40px; background:#fff url({T_THEME_PATH}/images/button1a.gif) repeat-x; position:relative; font-family:arial, verdana, sans-serif; }
.menu2 li.top {display:block; float:left; position:relative;}
.menu2 li a.top_link {display:block; float:left; height:40px; line-height:33px; color:#bbb; text-decoration:none; font-size:11px; font-weight:bold; padding:0 0 0 12px; cursor:pointer;}
.menu2 li a.top_link span {float:left; display:block; padding:0 24px 0 12px; height:40px;}
.menu2 li a.top_link span.down {float:left; display:block; padding:0 24px 0 12px; height:40px; background:url({T_THEME_PATH}/images/down.gif) no-repeat right top;}
.menu2 li a.top_link:hover {color:#fff; background: url({T_THEME_PATH}/images/button4.gif) no-repeat;}
.menu2 li a.top_link:hover span {background:url({T_THEME_PATH}/images/button4.gif) no-repeat right top;}
.menu2 li a.top_link:hover span.down {background:url({T_THEME_PATH}/images/button4a.gif) no-repeat right top;}
.menu2 li:hover > a.top_link {color:#fff; background: url({T_THEME_PATH}/images/button4.gif) no-repeat;}
.menu2 li:hover > a.top_link span {background:url({T_THEME_PATH}/images/button4.gif) no-repeat right top;}
.menu2 li:hover > a.top_link span.down {background:url({T_THEME_PATH}/images/button4a.gif) no-repeat right top;}
.menu2 table {border-collapse:collapse; width:0; height:0; position:absolute; top:0; left:0;}
/* Default link styling */
/* Style the list OR link hover. Depends on which browser is used */
.menu2 a:hover {visibility:visible;}
.menu2 li:hover {position:relative; z-index:200;}
/* keep the 'next' level invisible by placing it off screen. */
.menu2 ul,
.menu2 :hover ul ul,
.menu2 :hover ul :hover ul ul,
.menu2 :hover ul :hover ul :hover ul ul,
.menu2 :hover ul :hover ul :hover ul :hover ul ul {position:absolute; left:-9999px; top:-9999px; width:0; height:0; margin:0; padding:0; list-style:none;}
.menu2 :hover ul.sub {left:2px; top:40px; background: #fff; padding:3px 0; border:1px solid #4ab; white-space:nowrap; width:93px; height:auto;}
.menu2 :hover ul.sub li {display:block; height:20px; position:relative; float:left; width:90px;}
.menu2 :hover ul.sub li a {display:block; font-size:11px; height:20px; width:87px; line-height:20px; text-indent:5px; color:#000; text-decoration:none; border:3px solid #fff; border-width:0 0 0 3px;}
.menu2 :hover ul.sub li a.fly {background:#fff url({T_THEME_PATH}/images/arrow.gif) 80px 7px no-repeat;}
.menu2 :hover ul.sub li a:hover {background:#4ab; color:#fff;}
.menu2 :hover ul.sub li a.fly:hover {background:#4ab url({T_THEME_PATH}/images/arrow_over.gif) 80px 7px no-repeat; color:#fff;}
.menu2 :hover ul li:hover > a.fly {background:#4ab url({T_THEME_PATH}/images/arrow_over.gif) 80px 7px no-repeat; color:#fff;}
.menu2 :hover ul :hover ul,
.menu2 :hover ul :hover ul :hover ul,
.menu2 :hover ul :hover ul :hover ul :hover ul,
.menu2 :hover ul :hover ul :hover ul :hover ul :hover ul
{left:90px; top:-4px; background: #fff; padding:3px 0; border:1px solid #4ab; white-space:nowrap; width:93px; z-index:200; height:auto;}
</style>
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var perpage = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
</script>
</head>
<a name="top"></a>
<center>
<div id="wrap">
<div id="brd_outer">
<div id="brd_in">
<a href="{U_INDEX}"><img src="{T_THEME_PATH}/images/banner.png" width="940" height="250" alt="Welcome To TranceSounds: No.1 Place For Live Radio Sets" /></a>
<span class="preload2"></span>
<ul class="menu2">
<!-- IF U_PORTAL --><li class="top"><a href="{U_PORTAL}" id="portal" class="top_link"><span>{L_PORTAL}</span></a></li> <!-- ENDIF -->
<li class="top"><a href="{U_INDEX}" id="home" class="top_link"><span>{L_INDEX}</span></a></li>
<li class="top"><a href="{U_PROFILE}" id="products" class="top_link"><span class="down">Control Panel</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
<li class="top"><a href="" id="services" class="top_link"><span class="down">Search Post</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
<!--[if lte IE 6]><table><tr><td><![endif]-->
<ul class="sub">
<li><a href="{U_SEARCH_SELF}">My Post</a></li>
<li><a href="{U_SEARCH_UNANSWERED}">Unanswered</a></li>
<li><a href="{U_SEARCH_NEW}">New Post</a></li>
<li><a href="{U_SEARCH_ACTIVE_TOPICS}">Active Post</a></li>
<!--[if lte IE 6]></td></tr></table></a><![endif]-->
</li>
<li class="top"><a href="{U_MEMBERLIST}" id="contacts" class="top_link"><span class="down">{L_MEMBERLIST}</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
<li class="top"><a href="{U_FAQ}" id="shop" class="top_link"><span class="down">{L_FAQ}</span><!--[if gte IE 7]><!--></a><!--<![endif]--><!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED -->
<li class="top"><a href="{U_REGISTER}" id="privacy" class="top_link"><span>{L_REGISTER}</span></a></li><!-- ENDIF -->
<!-- IF not S_IS_BOT -->
<!-- IF S_USER_LOGGED_IN -->
<!-- IF S_DISPLAY_PM --><li class="top"><a href="{U_PRIVATEMSGS}" id="home" class="top_link"><span>{PRIVATE_MESSAGE_INFO}</span></a></li><!-- ENDIF --><!-- ENDIF --><!-- ENDIF -->
<!-- IF not S_IS_BOT --><li class="top"><a href="{U_LOGIN_LOGOUT}" id="home" class="top_link"><span>{L_LOGIN_LOGOUT}</span></a></li><!-- ENDIF -->
<div id="hdr"><div id="hdr_ls">
</div></div>
<div id="nav_btm"></div>
<div id="nav_shadow"></div>
<div id="menubar">
<td class="genmed">
<!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<!-- ENDIF -->
<td class="genmed" align="right">{CURRENT_TIME}</td>
<div id="wrapcentre">
<br style="clear: both;" />
I hope it helps.
