Ok so I have this template AZ Retro on my board and have installed board3portal and used prosilver for the style, which overall works fine with though with a little problem, all headlines becomes very big on the portal site. Any solution to this problem so it shows normal?
Portal in AZ Retro
Re: Portal in AZ Retro
Try enabling debug, it sound like you have an error.
P.S: Moving to English Support forum.
btw here is a link to the forum so you can see what I mean.
new theme problem solved with this.
