Hello
I'm one problem. I intalled a forum on local portal v1.0.6 and i'm install for 3 style but i'm one problem on the style nexus.
As you can see I lack the side block.
[img]I%20intalled%20a%20forum%20on%20local%20portal%20v1.0.6[/img]
Could you help me to correct problem?
Sorry for my english, i'm french and i use one translator.
Thank you for advance
portal for nexus style
Re: portal for nexus style
Please note that here:
- Translator
- phpBB.com User: Anywhere91
hi gortex and archivar
LINK / LIEN : http://www.rockettheme.com/phpbb3-updat ... e-released
Style Version: 3.1.4 to phpbb 3.0.7
No update since March 2010 Not sure this version is compatible with phpbb 3.0.8
Regards
In french / En français
Bonjour / Soir
Version du Style : 3.1.4 pour phpbb 3.0.7
Pas de mise a jour depuis mars 2010 Pas sur que cette version soit compatible avec phpbb 3.0.8
Cordialement
Regards
Bonjour / Soir
Cordialement
Thank you for your reply.
I' test the style for my forum phpbb 3.0.8 and is good except on the portal. is it possible to edit a portal to display those frames?
http://www.rockettheme.com/phpbb3-styles/nexusgortex wrote:Hello
https://www.rockettheme.com/join-a-club ... Cdevphpbb3
See a free download link for all.
I'm sorry I found a forum temlate sharing I did not know he was paying. So I let fall the changes since the use of a free way is illegal.
Sorry for the inconvenience and thank you for your answers.
